Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Quick Hid question
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Default Quick Hid question
    Hey guys, I have ordered these 4300k from Hid's Direct but won't be dispatched until after the holidays (4th Jan 2013) so just want to get some knowledge before they arrive.
    http://www.hids-direct.co.uk/h7-new-...-kit-slim-35w/
    They will be going into a Pre-facelift 2002 Vec C SRi 2.2 DTi which I think is half Canbus. I was wondering will I still have to get resistors and relays for these or is this setup a thing of the past due to more up to date ballasts? Plus will the light bulb itself just clip into my existing holders? Tried to call Hids Direct today to get more info but there is no one there until the 4th Jan. Should have read the notice about the holidays, too busy busting my arse getting them ordered....lol
    Had enough of the dim stock lights and trying all the different bulbs, as ya do and getting nowhere. I'm not too worried about the m.o.t as I will just disconnect them if I get a fail.
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    99.9% you will need Cancellers(think thats what you mean when you say resistors and relays). Or even better just get someone with tech2 or Opcom to activate the Xenon setting in the UEC for you. Your existing clips will need cut to fit over the bulbs, it can be done without cutting them but you run the risk of ripping the rubber seal. Check the how2, sure it shows you how to cut them.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    It'll be a straight fit. No cancellers or such, ideally activate xenon setting via tech2-opcom,
    Be prepared to take bumper off to get better access to fit ballasts on secure area, ideally under headlights so its not very revealing making it neat and tidy.
    Thats all, enjoy fitting them on ;-)
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Cheers Daz, thing is the only How 2 that I can find for the Pre-facelift model doesn't show any photos plus this is the one that says you need 0.3ohm resistors, capacitors and 5 pin relays although this was written in 2005….lol
    http://www.vectra-c.com/forum/showth...a-Vec-C-Signum
    I think the one I bought comes with anti flicker capacitors shown in the photo on Hids Direct, well I gather that’s what they are. Just hope this isn't gonna be a messing around match to get them fitted, was hoping the bulbs just clipped in the same as the stock one and just cut a hole in the blub cover.
    P.S. Didn't know I had to get tech 2 activated in my model, that's gonna be a mission as I don't know anyone that has one.
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Didn't think I had to take the bumper off either Great news and I ain't even got them yet.
    Quote Originally Posted by conman View Post
    Didn't think I had to take the bumper off either Great news .
    Why are so many people afraid of taking the bumper off, when it's so easy to do?
    Jun 2011
    wolverhampton
    Same kit as me and u need no cancellers and don't need to activate them. I removed the lamps to fit mine as I wanted them to look factory so drilled the bottom of the lamp not the cap. Your choice? Basically remove the metal clips off the power socket and cut the side so it will fit over the wires then twist the bulb and clip into place. Mount balast where you want it plug it in and test them. Leave on for ten mins first time you use them to burn the bulbs in as bulb life will be improved if burnt in well on first use. Best mod ever on a Vec c
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    123 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    It's no "biggie" fella, only a "couple" of screws, some guys have even found that their bumper is flexible enough to allow them to drop it enough just by removing the couple of screws in the wheel arches. After that it's plain sailing.
    It seems to me that with these canbus/halfcan cars that a code reader (under £20) is almost an "essential" part of your toolkit, and if you get the right kind, then it will also sort lots of other issues for you as well and pay for itself the first time you use it.
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    You wont, Pre-face so no need to remove the bumper to fit hids.
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    I know how to take the bumper of mate, problem is I don't have a garage and the weather is crap so the prospect of laying on the ground when it's ****ing down doesn't make it the most exciting job in the world. The only software and hardware I have for the car is VauxCheck and all it does is read and clear code and that about it. But reading your replies has sort of cheered me up a bit
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
