Thread: Spanner oddity?
    Oct 2010
    Lincoln
    Default Spanner oddity?
    Since having the EGR replaced, when I start the car first thing, after a few minutes the dreaded spanner comes on. Wait a few more minutes, restart car and spanner has gone out and remains out for the rest of the day? If I leave it with the EML lit I don't suffer from lack of power at all BTW.
    I read the codes a week ago and there were only 2, now there are 4, extra ones are the swirl flaps open/closed BUT it still telling me they aren't present?
    OP-COM 100219a - PC based diagnostic tool
    hkj
    OP-COM - CAN Communication Window> 2007|Vectra-C / Signum|Vehicle|Vehicle DTC Information
    Read Info...
    Identifier: 0x1001
    VIN: W0L0ZCF6871008116
    Hardware number:27539101
    Motor type: Z30DT
    Part Number:97353188
    Software version number: EC62M01S
    Programming Date: 20071207
    Hardware key number: H000005038
    System description: DENSO0100
    Type approval number: D06004
    Alpha code: BZ
    Hardware manufacturer system name: DECd2
    ECU variant coding: 0x0000B9D0
    Total number of fault codes: 4
    P0235 - Boost Pressure Control Circuit Negative Deviation
    (12) - Not present
    P1110 - Swirl Flap Stuck Open (Bank 1)
    (62) - Not present
    P1111 - Swirl Flap Stuck Closed (Bank 2)
    (63) - Not present
    P1900 - Diesel Particulate Filter Overloaded
    (55) - Not present
    I've looked at the DFP and it's sat at 60% so has anyone got any idea what the hell is going on?
    Clearing the codes just causes them to reappear as above?
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    They should clear as their saying not present.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    probably the glow plugs fella
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    You said swirl flaps replaced os the motor plugged in and working as they seem to contradict each other.
    i know it is possible for but not very likely.
    can you do a forced regen?
    Oct 2010
    Lincoln
    OK so why does the codes show not there? Don't think you can force a regen on a Z30DT? Readings say 60% on OPCOM.
    Battery disconnect to reset ECU?
    South East - Assistant RO jaqubek's Avatar
    Sep 2011
    london
    Vehicle : Vectra C Estate
    Engine : v6 3.0cdti
    Quote Originally Posted by lencuff View Post
    No you cant with ....COM, maybe with Tech2 but not sure
    Sep 2011
    london
    Engine : v6 3.0cdti
    (62) - Not present
    Got exactly same thing, but it comes and goes. Sometimes it shows every day for couple days when I start engine and after that nothing for few days and back again
  1. A/C oddity
    By lencuff in forum Engine & Drivetrain
    Last Post: 5th July 2011, 08:18
  2. Towing oddity?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 19:11
  3. V6 Diesel oddity?
    Last Post: 4th November 2010, 12:15
  4. e bay item oddity - what's going on here?
    By mark_w in forum The 'Off Topic' room
    Last Post: 1st December 2008, 21:16
  5. immobilisor oddity
    By appy in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2007, 21:07
