Thread: 1.9cdti auto estate 4th gear clunk
    Dec 2012
    nottingham
    Default 1.9cdti auto estate 4th gear clunk
    Hi.
    I was hoping for some advice with my car.
    Its developed a clunk in 4th, its the automatic gearbox.
    basically at 60-70 you press the accelerator, its goes into 4th but with a jerk?? you can also get it under load with manual select at 50mph.
    Is the gearbox terminal? If anyone has any ideas it'd be very much appreciated.
    thanks
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Change the oil in the box mate
    Dec 2012
    nottingham
    confused
    Just done a gearbox oil change and its made no difference. Is there anything else it could be or am i looking at a gearbox change
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Did you put 2.4 litres in it mate
    Dec 2012
    nottingham
    Quote Originally Posted by paulvectrac View Post
    Im not a mechanic so took it to a local garage, he said he used 4 litres, i believe some of that was used to flush the gearbox out first.
    He said the old oil was brown and smelt quite bad.
    Could the amount of oil effect the clunk?
    appreciate you taking an interest on this
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    Does an auto box uses same amount as manual ?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Flushing the torque converter is the hardest part in situ.
    Up to 10 litres might be needed.
    AF33 5 speed gearbox uses 4 litres VX part# 93160393
    AF40 6 speed gearbox uses 4 litres VX part# 93165147
    The valve blocks are prone to wear but a Tech 2 gearbox scan might reveal something else.
    Failing that........
    Take it to a automatic gear box specialist and get them to check it out.
  1. 2005 Vectra C 1.9cdti Elite estate - Auto box changed to manual
    By seanr28 in forum Engine & Drivetrain
    Last Post: 24th September 2011, 22:06
  2. 1st>2nd gear clunk - CDTI 150
    By cacbabble in forum Engine & Drivetrain
    Last Post: 10th June 2011, 04:10
  3. Auto gearbox clunk
    By ncfcsignum in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 22:18
  4. Auto gearbox clunk
    By ncfcsignum in forum Engine & Drivetrain
    Last Post: 7th October 2010, 22:18
  5. clunk under the car when changing gear
    By sharpo in forum Engine & Drivetrain
    Last Post: 24th July 2009, 15:41
https:www.vectra-c.comforumshowthread.php178233-1-9cdti-auto-estate-4th-gear-clunk
