Results 1 to 10 of 16
Thread: Overheating 1.9 diesel
    Mileage : 000
    Default Overheating 1.9 diesel
    A mate at work has a 1.9 Diesel signum, he has this problem where on the way home from work it went into the red after a couple of miles. He stopped the car to let it cool, then after a couple of miles it did the same. Also when he puts the heater on to hot there is only cold air coming out. Any of you 1.9 diesels owners had this problem, or does anyony have any pointers for him to look at. Cheers Lads.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Blocked in the systen somewhere mate or stat is stuck open
    Jan 2010
    wirral
    ..........water pump??
    Dec 2011
    Seaham
    Try taking the stat out and testing it. Stat may be stuck closed. If it isnt the stat then it has to be a waterpump problem.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'd be suspecting a water pump failure
    Nov 2010
    East Midlands
    Trim : design
    Also chance the timing belt may go if the pump seizes
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Water Pump
    If it seizes, it'll snap the timing belt.......
    Mileage : 000
    Yes I did say to him if it is the water pump there is a better than good chance it will loose the belt then game over for the engine. If it is the waterpump, he was very lucky to get home, he had about a 20mile drive.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Mine has just done this too! Did he get to the bottom of the problem?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by stevoxsi View Post
    Very likely to be the pump mate... Stats are designed to fail open and therefore you wont get any heat. Unless you have just done a coolant change and there is possibility of a air block - looks like pump. My advice is do not drive it before its looked at. If that takes the belt out - you have problems.
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  3. overheating
    By jonesey42 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:24
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
56 vectra 1.9 cdti overheating
