Results 1 to 10 of 21
Thread: 1.9 injector washer problem
    Nov 2012
    n.ireland
    Default 1.9 injector washer problem
    hi guys i have a persistant problem with my 150.
    the injector washers went on no 1 and 2 so i had all replaced. then a few months later no 2 and 3 went i asumed that they hadnt been cleaned properly so had them changed again (cleaned properly) run perfect, but a few days later no 2 and 3 went again.
    has anyone had a similar problem and know why they wont seal?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Yeah, when re building mine after belt went it took 3 attempts to get them to seal longer then a few days, still don't trust it now but so far so good...
    I gave everything a good clean and last time I used a bench grinder with wire brush wheel to clean and scuff the seals, may have helped...
    Nov 2012
    n.ireland
    thanks mate ill have another go at it. been thinking of getting something new as she has give me nothing but bother is the 2.2 any better?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get proper tool to recut injector seats.
    Nov 2012
    n.ireland
    the proper tool was used the last time they were changed.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are you using a torque wrench to tighten then injector clamps?
    Nov 2012
    n.ireland
    im not sure if he did or not. are you meant to and how much?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I had this problem, recut the seats myself (tool about £30-£40) fitted new washers and has been fine since
    just be careful not to cut the seat too much.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Derv-head View Post
    When I fitted my injectors I had the exact same problem. I did not recut the seats but I cleaned the bores impeccably fitted new washers....I tightened the clamps down connected the fuel pipes etc. and then started the car up. I thought everything was fine until a few days later I noticed a burnt diesel smell inside the car. I sprayed soapy water around the injectors and 1-3 were all bubbling like hell.
    I then removed those three injectors, cleaned everything again and started it back up. No. 1 was fine but 2 and three were still leaking as most know, you have to remove the injectors in sequence meaning I had to remove the newly sealed no.1 Injector. Cleaned all again, put back together and still two were leaking. It was then I decided to buy a smaller torque wrench from halfords to torque up the injectors. Numbers 1-3 nuts turned twice from what I thought was pretty tight and even number 4 turned once. That was nearly a year ago now and I've had no problems since
    Don't quote me but I think the torque level was about 35nm which I could double check for you tomorrow if you need
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    heres the tightening torques
    Install stud bolt
    Tighten stud bolts 14 Nm
    Unscrew 2x counter nut
    14. Fasten injector
    Tighten new nut 25 Nm
    15. Install 2x high pressure line when replacing injector for
    cylinder 2, 3 or 4
    Important: When securing the lock
    nut, counterhold at injector with open-ended wrench
    Install new high pressure line of cylinder concerned
    Remove sealing plug
    Tighten lock nut (M12) 25 Nm
    Tighten lock nut (M14) 23 Nm
    Install new high pressure line of the cylinder directly on the
    left (seen from the front)
    Remove sealing plug
    16. Install new high pressure line 1 when replacing injector for
    cylinder 1
    Remove sealing plug
    17. Install engine vent pipe when replacing injector for cylinder
    1
    Attach hose
    Fasten clamp
    Clip in 2x wiring harness
    Tighten 2x bolts 9 Nm
  1. Injector Problem
    By vectra19 in forum General Motoring Chat
    Last Post: 8th June 2012, 23:40
  2. 150 injector problem
    By lee640 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 21:13
  3. Injector problem
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 29th July 2009, 13:58
  4. 3rd injector problem
    By smurfy in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:56
  5. EGR or INJECTOR PROBLEM
    By dingle in forum Engine & Drivetrain
    Last Post: 18th May 2008, 16:56
