Thread: Power loss like limp mode no code/light
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Power loss like limp mode no code/light
    Ok, now i'm getting that no boost power loss while driving, no car with spanner lit up when that loss of power happen mid journey.
    Can you list things that can cause that??
    Injectors? Turbo outlet going through emission system could it be struggling to discharge emission? Dpf was full, but i guess its full again!
    What else could it be?? Boost power fine rest of journey apart from that 15 second loss of turbo power!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Clean EGR and boost sensor.
    Check all vac pipes for perishing / splitting / cracks.
    Clean / remove filter on boost control solenoid.
    HTH
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by tony-1977 View Post
    HTH
    Egr blanked (emission light staying on but ignoring that)
    All vac/boost been checked, retightened, all good
    Boost sensor cleaned recently
    Bcs cleaned, re-lubed and deep clean filters both round and rectangle, new vac hoses fitted. Inside tubes on old ones clean
    Still not fully solved the issue! :-(
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you checked the DPF with Tech2 or similar? Might be still full and need a regen.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Might force regen again. Since blanked, good idea to have it cleaner really
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Boost solenoid stuck open
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Critch View Post
    I bought new one. Cant have got stuck.. Will remove and inspect.
    Any others??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Think the DPF is definitely blocked.. Had regen again 4 days ago, i gave it a lot of boost, drove superbly for past 4 days afterwards, now get no boost after doing same thing yesterday. Remap might be needed, need first is dpf pass thru if anyone got one??
  1. Limp mode - no power :(
    By Big Knox in forum Engine & Drivetrain
    Last Post: 1st March 2016, 12:26
  2. Fault code and limp mode
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 7th February 2012, 20:58
  3. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 6th June 2011, 18:55
  4. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  5. Anyone got a code reader? My car is in Limp mode... :(
    By wingz123 in forum Troubleshooting
    Last Post: 29th March 2011, 00:40
renault scenic limp mode no codes
