Thread: One step forward two steps back help please !!
    Dec 2012
    Banbury
    Default One step forward two steps back help please !!
    Ok when I brought this car realised the radiator fan doesn't cut in so I checked the fuse and it had blown put a new fuse in eml went of so let the car ideal got to 100 got pretty worried then turned it of and back on a little later once had cooled down and eml back on and fuse popped again ideas anyone :s also the top and bottom radiator hose felt really hard like pressurised hope someone can help can't drive it till this is sorted
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    - There could be a short in the fan circuit somewhere.
    - Or maybe the fan motor is faulty, causing the fuse to blow when the fan cuts in.
    An auto electrician should be able to diagnose it for you
    Dec 2012
    Banbury
    How do I go about looking for short circuit ?
    also will it have anything to me unplugging the climate controll ?
    I wanna try fix it myself today
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I may be wrong on this, but I'm sure the fan and climate control work together Someone will confirm this I hope
    Could also connect the fan motor direct to the battery for a moment (use a fused live), and see what happens (fuse blows or fan works)
    Dec 2012
    Banbury
    I was thinking the same about the climate controll but would it blow the fuse ?
    Can anyone confirm about climate controll
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You have a short if its blowing the fuse.
    The easiest way to test for short is you test lamp over fuse holder. ( bulb lit means active short)
    then systemically disconnect the circuit. Once light goes out you know its in that part of circuit.
    but as said any good garage/ auto spark find it relatively easy.
    it might just be a case of fan motor shorting
    Dec 2012
    Banbury
    Thanks mate it's just problem after problem with my signum ATM
  1. can someone give me a step by step guide to...
    By taffy bhoy in forum Bodywork & Interior
    Last Post: 5th December 2011, 16:53
  2. HELP seats not sliding forward or back,
    By cruicky27 in forum Bodywork & Interior
    Last Post: 29th October 2010, 13:00
  3. step by step guide
    By dezwez in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2010, 17:30
  4. my first PS steps
    By Felix [GER] in forum Photoshop section
    Last Post: 15th February 2010, 15:01
  5. Taken the first steps now...
    By danBoy in forum General Chat
    Last Post: 20th August 2008, 19:16
