Thread: Stripping a Full Canbus Facelift - Where do I find the TPMS units ?
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    178 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Default Stripping a Full Canbus Facelift - Where do I find the TPMS units ?
    Hi Guys,
    NOT as per the heading, I will start stripping down a "new" donor Pre-Facelift Full Canbus car later today, purchased because it is just too high spec to let go to a scrapyard without relieving it of some of its assets first
    One of the first items I want to remove is it's factory fitted TPMS system, the difficulty is that it is the last of the pre-facelift models and has a Full Canbus rather than a HalfCan. So, where can I locate these units guys and what wiring do you think I should remove just in case I want to retrofit these into another car later ?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The front receiver is in the left hand inner wheel arch fixed to the bulkhead, the rear receiver is fixed on the inside of the rear wheelarch liner passenger side, if its a hatch then the control unit is in the boot cubby hole on the right hand side, the estate has the control unit just behind the left hand rear seat high up on the bulkhead. Take the wiring looms as far as you can and for the rear wheel receiver take the whole rear axle loom to the x5 plug.
    May 2012
    178 Post(s)
    Mileage : 131,000
    Many thanks Paul. Can I just"qualify" with you as to what exactly the rear axle loom is, and as per its description, does it actually lie on the axle and where is the x5 plug ? Or do you mean literally everything, including lighting ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Do the pre facelifts not need 4 receivers? The facelift only has two - as mentioned by Paul.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The full can pre or facelift have 2 receivers Gaz the offside 2 wheels are detected by the control unit, the X5 plug is under the rear passenger seat but underneath the car and yes the whole axle loom and it is fixed across the rear axle.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by paulhb View Post
    Just as Woodpecks is registered in 2004, when he comes to fit it he may need another two recievers depending on when his car was registered (before or after October 2004).
    May 2012
    178 Post(s)
    Mileage : 131,000
    Thanks guys, this sounds like it might be more than just a "tricky" job now that the car is "sitting" in a "field" with no engine lol
    Will be giving it my best shot anyway.
    Cheers fellas
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    http://www.ebay.co.uk/itm/VAUXHALL-V...item416f9b1dab
    heres an elite might have what you need.
    May 2012
    178 Post(s)
    Mileage : 131,000
    Quote Originally Posted by rozzer2006 View Post
    Thanks rozzer, I've sent the guy an email
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
  1. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  2. 2005 vectra 2.2 sri, preface or facelift half-can or full canbus?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2012, 13:41
  3. Steering controls in silver full canbus pre facelift
    By merikiito in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th October 2008, 10:48
  4. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
