Thread: Hesitant after water pump change
    Aug 2011
    Bristol
    Default Hesitant after water pump change
    Had the pump changed yesterday.
    All seemed fine when I had it back and when he was running it.
    Once I drove it it seemed a little slow.
    When trying to go up the revs around 3000 it seemed to slow a little and then go normal at 3500.
    Kept driving to see what occurred.
    When I tried accelerating again hard it felt low revs and then engine management kicked in. When stopped at roundabouts it was stuttering as though it was going to die. Didn't though
    Turned off and started again it cleared.
    Came on 2 times more and now stays with the car still running a little sluggish.
    I would have thought EGR either gone or needs cleaning.
    Does this sound right with the symptoms?
    Nothing else seems of issue.
    If so what would be best, clean the thing up or blank off??
    I am not asking for pages of opinions as I have seen the discussions about blanking this.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Which engine? Sounds like when they put the timing belt on its maybe gone out a tooth.
    Aug 2011
    Bristol
    Z22YH.
    Timing was not removed to change
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    thought the water pump was driven by the timing chain on these , although I have never replaced one s couldn't say for certain what is or isn't involved
    Aug 2011
    Bristol
    Misfire in 1 and 4.
    Fault now cleared and not come back.
    Either faulty ignition coil or I think a little left over water from the seal gone on pump.
    Will take plugs out and clean them up (still only 2 months old) and see what happens.
    Oh, and pump is connected to the balance chain but as long as you have a tool the chains don't need to be removed to take the pump out
    May 2012
    county durham
    Mileage : 145k
    Quote Originally Posted by GCusdin View Post
    Misfire in 1 and 4.
    hopefully all good then , fingers crossed
    Aug 2011
    Bristol
    I have every finger crossed and toes.
    1 and a half grand so far for engine rebuild, 300 on steering rack and still things keep cropping up. Next time advice for anyone, replace engine. Much easier.
    Just brake pads, drop links (a year and 1 month after new) and a good clean left to do. Then gonna see what it's worth as I aint doing this again
  1. misfire on 1 and 4 after water pump change
    By GCusdin in forum Engine & Drivetrain
    Last Post: 18th February 2013, 18:56
  2. water pump change
    Last Post: 12th December 2012, 15:28
  3. Cambelt and water pump change
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 14:39
  4. Cambelt kit & water pump change
    By Pete1nlancs in forum Engine & Drivetrain
    Last Post: 30th July 2010, 19:07
  5. Cam Belt & Water Pump change...
    By si_sri in forum Engine & Drivetrain
    Last Post: 27th June 2010, 21:48
