Thread: Intermintant wipers not working help please
    Dec 2012
    Suffolk
    Default Intermintant wipers not working help please
    Hi, Help please. I have an 03 Signum, 2.0T Elegance. I don't appear to have a rain sensor. But my intermintant wheel is not working. I roll it to the left nothing happens, then when I roll it to the right it swipes once for every click and thats it.
    A little advice please.
    Feb 2011
    Selby
    Are you sure you don't have a rain sensor? Firstly an Elegance should have it, and secondly the behaviour (one wipe when moving the wheel a click to the right) is what you'd expect from the rain sensitive wiper system. Look where the rear view mirror is on the outside of the windscreen, that's where the sensor is. Try putting the wipers on the most sensitive setting (fully to the right) and spraying the area with water. It could be that your sensor has failed or is dirty, or the loom is broken, and it's not detecting rain. Mine didn't work after I had a new windscreen fitted - the fitter had used too much silicone oil when refitting the sensor and it wasn't very sensitive. A little wipe with cotton buds to remove the excess and it's been spot on ever since.
    Dec 2012
    Suffolk
    I have seen other posts in regards to this and seen photos of screens with rain sensors. It's a dark patch with a small square window in the middle. Mine is a plain screen and no sensor. Now starting to think it may have been removed when a screen was replaced before I purched the car.
    Confused.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    that spec of car should have the rain sensor & the auto dim mirror as already said , so if these are not present then maybe someone has had a windscreen replaced with the cheaper option .
    Feb 2011
    Selby
    Yes, it could well be that they fitted the wrong screen. Do you have the auto dimming rear view mirror? Maybe take off the interior light and see if you can see the loom that should go to the mirror and the rain sensor. The rain sensor one has 'regensensor' on it near the end. I wonder if the rain sensor is still connected, but chucked up in the roof lining.
    If the sensor is disconnected, the wipers revert back to standard intermittent operation - ie the positions of the wheel on the stalk control the time between wipes.
    Dec 2012
    Suffolk
    Brill sounds good I do have the auto dimming rear view mirror. Maybe the dullard who replaced my windscreen has put the sensor into the roof lining. There looks like there is a clip for the sensor. I will have a look at it in the morning.
    Dec 2012
    Suffolk
    Gents I have pulled out the ultra sonic sensor and had a look inside. There is no rain sensor there. ******!
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Is this a new fault or has the intermittant never worked ?
    There is a known problem with Vectra wipers behaving strangely in freezing conditions - some sort of bad earth in the motor unit.
    Look at this how to :
    Look at this :Forum
    Technical
    How 2's
    How to Repair Common Fault on Vec C/Signum Front Wipers
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Dec 2012
    Derby
    hi im new to this site so 1st things 1st hi all happy new year 2ndly i have 52reg vectra c and my intermittant wiper is playing up ive changed the rain sensor and tried turning the sensitivity up but it will not work below 40mph from 40mph and above it works fine? help its starting to really bug me
  1. wipers not working on 2nd speed
    By Seanyboy in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2011, 18:55
  2. Wipers have stopped working
    By myhotholden in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2008, 03:44
  3. wipers not working when cold
    By johnnyg in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2008, 21:45
  4. Auto wipers - working but...
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 23:12
