Results 1 to 10 of 17
Thread: Rear brake replacement advice
    Aug 2012
    Rugby, Warks
    Default Rear brake replacement advice
    Hi Guys,
    the time has come for me to replace the rear discs and pads on my 2003 signum.
    I'm aware that i'll need a caliper wind-back tool, but are there any other things to consider? do they have handbrake shoes inside the rear discs etc...?
    Belated Merry Christmas to you all! hope you had a good one!
    Regards,
    James.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    It's just a disc and pad set up. No shoes in the discs
    Regular Member Keif's Avatar
    In the Garage
    No shoes for the handbrake, it all works of the pads (badly).
    Only thing i'd suggest is a wire brush/thin blade to clear and road dirt from under the handbrake lever on each caliper and some WD40.
    Aug 2012
    Rugby, Warks
    Awesome, cheers guys! I didnt want to get it up on a pair of stands and then find out it was more of a job that I though. that's great! cheers for the advice also, i'll do that.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    You will need a female torx sockets e18 or e20.
    Aug 2012
    Rugby, Warks
    Quote Originally Posted by cliomjh 102 View Post
    Ah, ok. I have a set so that's fine. cheers
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    And perhaps a breaker bar if the torx bolts are tight and they usually are
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    7mm allen key for the slide bolts too.
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    Just don't do what I did and strip the thread on the bleed nipple
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Remember to take off the brake fluid cap and after you have finished changed the disc and pads, depress brake pedal first till it's high before you pull on the handbrake.
  1. Rear Brake Disc Advice
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 10:03
  2. Rear brake pad replacement
    By larryj in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2010, 21:14
  3. How much for brake pad replacement?
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2009, 19:53
  4. Vectra Rear Hydraulic Brake Line Replacement ???
    By Markuk27 in forum Handling & Braking
    Last Post: 20th May 2009, 02:35
  5. rear brake pad replacement.
    By mick 1986 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 09:47
