Results 1 to 10 of 20
Thread: 1.8vvt stat change coolant question
    Nov 2012
    Wakefield
    Default 1.8vvt stat change coolant question
    Hi all,ive recieved my new stat and housing today,im going to change it tomorrow on my 1.8vvt,the thing is the coolant is only 3 month old so whats the best way to do it without loosing too much of the coolant?
    cheers
    nick
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Leave the lid on the coolant bottle.
    use a rag an pair of mole grips on rad hose.
    undo and replace stat
    refit hose remove clamp.
    undo coolant lid. Run up and top up as necessary. pump rad hose to help remove air locks
    should loose less than 1l doing it that.
    Nov 2012
    Wakefield
    hi which rad hose do i clamp,and you say refit hose and remove clamp?
    cheers
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Or just drain off the coolant into a clean bucket, via the hose from the thermostat housing.
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    The hose going to thermostat. I meant remove clamp as in mole grips sorry.
    or as above drain system into clean bucket and refill
    Nov 2012
    Wakefield
    hi the hose going to the thermostat is one big one on the 1.8vvt, what about the coolant in the block
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Refill with Evans Coolant... Be a Guinea Pig for the rest of us...!
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Once you release the coolant tank cap, then the top hose, the coolant will find its own level through the rad. On the z18xer the other hose goes direct to the water pump, the bypass hose should allow the coolant in the head to drain out into the radiator. You shouldn't lose very much, if any coolant, when you remove the stat.
    Nov 2012
    Wakefield
    cheers guys so its just a case of removing the top hose that connects to the stat and draining into a container then that should should empty the block enough?
    thanks
    Nov 2012
    Wakefield
    job done today instead,just drained the coolant from the hose connecting to the stat housing,lost some, but caught 4 litres maybe lost about 1 ltr, issue i have now is i filled the header tank to the usual place and still had 2 ltrs left to put in, ran the car upto temp then there were a few clangs etc and the level dropped in the expansion tank, at this minute its about 1 inch below normal level, but when i run the car the temp gets upto 97 deg,and the tank fills back up with coolant then overflows, the fans arent kicking in and the heaters are blowing cold,ive left it for 30 mins or so running to get all the air out,im leaving it overnight to settle and will run it back upto temp tomorrow,but does it just sound like an airlock somewhere?
    cheers
    nick
  1. whats needed to change stat on a dti
    By peadar in forum Engine & Drivetrain
    Last Post: 9th December 2011, 08:02
  2. Plug change 1.8vvt sri
    By big oak in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2011, 20:04
  3. 1.8VVT Don't neglect spark plug change!
    By peter_ in forum Engine & Drivetrain
    Last Post: 11th May 2011, 21:07
  4. Hydraulic Pulley on 1.8vvt Cambelt Question?
    By 67688c in forum Engine & Drivetrain
    Last Post: 31st August 2009, 17:21
z18xer coolant change
how much coolant to fill up vauxhall vectra 1.8
how much fluid in litres for coolant system for vauxhall vectra c 1.8 sri
vauxhall vectra c 1.8 coolant amount
vectra c 1.8 radiator removal
z18xer air bleed
vectra c 1.8 sri how to drain coolant and replace
vectra c radiator top up
antifreeze for vectra c 1.8
vauxhall vectra 1.8 sri vvt break coolant filling
vectra 1.8 vvt antifreeze
vectra c 1.8 coolant replace
how much fluid in coolant system vectra
vectra c 1.8vvt coolant
change coolant vectra c
vectra c coolant change site:www.vectra-c.com
vauxhall insignia vvt Sri 1.8 2009 model anti coolant
2006 vectra 1.8 coolant amount
how to fill and bleed thw coolant on a insignia 1.8
is there any coolant bleeds on the insugnia 1.8vvt
vectra 1.8 vvt coolant change how often
vectra c 1.8vvt coolant ratio
vectra c water overflowing when bleeding coolant
https:www.vectra-c.comforumshowthread.php178191-1-8vvt-stat-change-coolant-question
