Thread: MAS Performance question
    Oct 2012
    Burnley
    Default MAS Performance question
    Hi all,
    Got myself a 1.9cdti 150 Siggy a couple of months ago and wish I had seen this site before hand. Its a 56 plate with only 53,000 miles with full vauxhall service history. But it would appear it was only used for short journeys by the previous owner, so the usual problems started with the inlet manifold, DPF etc. To cut a long story short Ive had a new inlet manifold fitted under warranty and when i got it back they also said that the DPF was blocked so they carried out two forced regens and the car seemed alot better, it feels like the power is slowly decreasing again. I suspect as read on here that DPF is knackered so Im thinking about getting into MAS to sort the DPF and prevent any damage to the new inlet.
    Since i've had the car i suspect its never been at full power, so I dont know whether or not to get a performance map aswell or just get the DPF & EGR mapped out and the DPF removed and keep the standard map.
    Has anyone just had this done or has everyone had a performance map? If you kept the standard map did you notice any difference in performnce when you removed the DPF.
    Cheers (sorry for the essay)
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    have a look in deisel tuning section m8 ive got bens map and egr deleted its a different car now(approx 190 bhp) didnt have a dpf thank god but i think once deleted you can just gut it ,but do have a search on here .hth
    Do it - get it all taken off and the performance map and it'll become the car it should have been from the factory mate. Ben has done loads of us on here and he's a top chap...
    Regular Member dezzyb66's Avatar
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Engine : 1.9cdti 120
    Im gathering Ben is down south if so does anyone know of anybody up the area of carlisle that does remapping cheers Dez
    Unless he's moved he was in west Yorkshire last time I checked...
    Oct 2012
    Burnley
    Well its booked in for next friday
    I'll speak to Ben when i get there but from what im reading on here its all positive. Im just paranoid about overstraining the engine etc with a performance map, as you hear all sorts of stories but I haven't seen as bad thing on here about Bens maps.
    Should be interesting if the car is already down on standard power and i do go for a performance map.
    Stupid DPFs, & EGRs, more hassle than they are worth, I hope ill end up getting better mpg too as its rubbish at the moment. Ill let you know how I get on....can't wait.
    The engine can handle it fine mate - treat it with mechanical sympathy (warming up etc) and don't thrash it everywhere and it'll be more than fine. The engines are under-stressed with the standard map which is all about emissions - by using the performance map you're simply using the engine to it's proper capabilities.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Penfold101 View Post
    Nov 2010
    doncaster
    ben at mas did my veccy when i had it cdti 150 remapped to 187.5bhp and it was a flyer not one problem the only problem was i traded it for a new antara nice motor but miss the power and economy boo hoo ben really knows his stuff
  1. Signum 2.0t performance question
    By redryan in forum Petrol Engine related
    Last Post: 24th January 2013, 21:29
  2. 2.2 DTI performance
    By jammy_c in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 23:49
  3. 2.2 Performance Question
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2011, 17:45
  4. MAS Performance
    By damers2000 in forum Diesel Engine related
    Last Post: 26th August 2011, 08:11
  5. Performance box Measure your cars performance..
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2007, 18:09
