Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: eBay wheel bearings
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Default eBay wheel bearings
    Has anyone used bearings from eBay? I've got a front passenger wheel bearing which is wearing and making a droning noise when driving I've found a kit on eBay which includes new bolts, driveshaft nut and cover for £52.50 delivered would this be ok? Mines a 2007 Sri 1.9cdti 8v. it is the facelift bearing which is Ids+ compatible.
    Stephen
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Maybe depends which company you use. I bought a new front wheel bearing kit, it was around £50 and whithin two weeks it was knackered, first I noticed the steering felt vague as though the wheel nuts were loose so I pulled over to check thinking I had been slap dash putting it back together but they were fine, when I tugged on the wheel they were loads of play top to bottom and that was all in under 300 miles I contacted the company and they were tos@ers about it. I had to buy another before they would send a replacement and claimed I was talking rubbish and one of there engineers would check out the returned bearing. I put a sneaky mark on it where they wouldn't notice in case they tried to be awkward but surprise surprise it went missing in the post apparently, so no refund. Because I need my car I had to order another bearing to put in as soon as the old/new was removed, the difference in play while both on the bench was MASSIVE must be real shoddy quality, the replacement bearing was from the same company as I was hoping for a refund. The new bearing has been on a little while but also has some movement on it which I'm not overly happy about considering the opposite side is original and has 110 000 miles on it and is still perfect.
    Sorry for the long winded reply but that was my experience. I wonder if I should name and shame.
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Thanks mate, might be lmf I use then lol
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    This is the one I was looking at using
    http://www.ebay.co.uk/itm/Vauxhall-V...-/110944218210
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does it show the make of the bearing? Most half decent non genuine wheel bearing kits start at about £75-80. I normally fit FAG bearings to cars I have in to fix (only ever use genuine bits on my own)
    Cheap ones can play havoc with abs systems too
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    I was rooting through my old eBay account and found them azcarpartswakefield is the company I used. Hopefully others are better but this lot I would avoid, hopefully it will save some potential hassle
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Can you name and shame? Would be good to know for future reference
    Guess i'll be fitting genuine bearings to my car when they go.
    EDIT: Thanks for naming them
    Last edited by XPCobra; 27th December 2012 at 00:35. Reason: Took too long to post
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by woody in shetland View Post
    Unfortunately your contact are wholesalers/retailers, what we really needd to know is who actually manufactured the bearings. Probably does not help you, but lets everyone else know who to avoid.
    3.2 v6 Signum and loving it
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    That makes sense, but at least avoiding these wholesalers it may avoid who made the bearings. Who actually made them I have no idea, sorry.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Totally get your point. Your supplier should be doing all he can to help. They sound as if they are not the correct specifications, therefore not fit for purpose, you must have a case against them.
  1. Wheel Bearings?
    By PedroMV6 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 16:56
  2. wheel bearings ????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 20:52
  3. Wheel Bearings
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 13:52
  4. wheel bearings
    By scottietlr in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 17:34
  5. wheel bearings
    By blackbeauty in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2007, 21:21
