Thread: Lowering kit help needed please
    liverpool
    Default Lowering kit help needed please
    All sorts of noises from back of my Gsi since bought it. Not a mechanic but when looked springs appeared shot to me. Decided would invest in some lowering springs. Having spent hours searching site and pm'ed several members my mind was firmly set on pi springs 45/40. Read reviews on eibach, apex etc but want it drive able low and think this is the route. I have now been told that shocks are bit past it and also need replacing. Despite my research can't decide best route to go now. Pi shock/spring set on eBay for £280. Any good? Or should I get bilstein b4s with the pi springs? Am on a budget and realise people will say b6s better option but to steep for me. Any other options? All help appreciated.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I have the bilstein/eibach setup, you can get them for around £600 delievered, Maybe twice your budget but they will be twice as good.
    I tend to find that cheap shock absorbers start to knock very early in their life, however i'm not sure anybody on this site has tried the pi spring/shocker combo.
    Bilstein b4's are a replacement item for non sri/gsi vectra models btw, so unsuitable for sri/gsi models and thats before they are lowered!
    If the rear end is knocking, have you checked your upper control arm bushes, these commonly wear and cause a knocking noise (£30 for two new arms) The rear ARB D-bushes also wear out (under £10 for genuine new bushes) Have also seen one or two rear droplinks wearing (not sure on cost but another cheap fix)
    While your replacing parts of the suspension get everything checked over to see if anything else needs replaced ( front droplinks, rack ends, track rod ends etc) and last of all whenever your finished sorting / upgrading the suspension get it four wheel aligned, makes a huge difference and will be sure to put a smile on your face
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'd personally got with bilstein/ Eibach combo I have irmscher suspension so same as b6/ pro line set up.
    and it's a combo I'd definatly use again.
    as said above make sure everything else is checked. You may find that milage dependant you end up changing them anyway.
    when I changed my suspension. I also changed. Top mounts and bearings, drop links and anti roll bar bushes. So I could be sure everything was ok.
    As at that point the upper control arms had only been replaced about 10k previous
    liverpool
    Eibach only lowers 30mm and want it to go slightly lower. If money no object, take it bilstein b6's with pi springs better option.
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Bilstein b8s are the better option (same as the b12 combo kit)
    b6s have standard length pistons, b8s have shorter ones better matched to lowering springs.
  1. Help needed sourcing lowering springs
    By Lao in forum Handling & Braking
    Last Post: 5th September 2012, 16:06
  2. help lowering advise needed
    By johnytaff in forum Handling & Braking
    Last Post: 8th February 2011, 22:10
  3. 2.2 lowering advice needed
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 22:43
  4. Lowering, Pics Needed With Snowflakes
    By Robbie69 in forum Handling & Braking
    Last Post: 3rd August 2008, 13:52
  5. advice needed on lowering springs please
    By madmark in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2008, 07:41
