Results 1 to 10 of 11
Thread: Oil filter housing 1.9 CDTI
    Nov 2012
    Essex
    Default Oil filter housing 1.9 CDTI
    I've always done the oil & filter changes on my cars & must have removed a hundred oil filters in my time but I met my match getting this B£$%%"y thing off.
    I jacked the car up & put on 2 axle stands at the front. Dropped the cover off, got a 32mm socket on the plastic filter housing but there was no room to move the ratchet. I used one of those flexible adaptors & eventually heaved it loose. It must have taken me a good hour to get it to move. I couldn't get the socket & ratchet into a position where I could give it a good hard pull.
    I greased the thread of the housing when I put it back & tried not to do it up very tight to give myself an easier time when I next change the oil.
    Is there an easier way?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I use the ratchet from the top of the engine to undo it. A bit more room plus it's a lot more comfortable
    Admin plasma's Avatar
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    Did mine from underneath only takes a few mins I did buy some proper tools which includes a shallow socket
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Piece of cake from the top. Pop the coolant expansion tank out the bracket and you can get your arm in easy
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Yup another one for moving the expansion tank and getting it from the top
    East Ayrshire
    Trim : SRI XP1
    12 inch extension running through towards the passenger side done it for me
    Nov 2012
    Essex
    Think I'll remove the expansion tank and go at it from the top next time. Thanks guys
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Yep, tank out the way for me and a short extension worked a treat.
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Shallow socket and extra long ratchet. Is money well spent.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Do it from top. I agree its a pain. Design flaw that one!!!
  1. V6 CDTi Oil Filter Housing problem
    By smitd004 in forum Engine & Drivetrain
    Last Post: 21st June 2011, 10:27
  2. 1.9 cdti fuel filter housing
    By jc2k5 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 13:00
  3. Location of fuel filter housing 1.9 CDTi
    By bennettboy in forum Engine & Drivetrain
    Last Post: 1st October 2008, 23:15
