Thread: Problem number 2 :(
    Dec 2012
    Banbury
    Default Problem number 2 :(
    Ok my heaters don't work the climate controll panel doesn't light up or nothing looked in the manuel and the fuse box next the glove box has 2 7.5 amp fuses and one big 30 amp fuse so the big one was missing and so was a 7.5 amp so I put the big one in and the blowers work without ignition on but panel still doesn't lights up and if I plug the other 7.5 amp the unit lights up no blowers and just clicks like crazy, bit puzzled what it could be ? Any ideas
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    mine went off before , no idea why & I was out somewhere with no access to any kind of tools .
    I suspect mine might have had a dodgy connection on the CIM as I pushed the steering wheel forward & pulled it back a couple of times then when I started the car it worked .
    Dec 2012
    Banbury
    Anyone ideas
    Dec 2012
    Banbury
    Anyone??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Take panel off, start car. Plug panel back on. Turn blower on. If no luck, resetting might be needed, (disconnect battery for half hour.)
    Repot back :-)
  1. Number plate light problem.
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2012, 17:28
  2. Rear Signum Light problem problem - help
  3. Wiper Electrical Problem? (Not sticking or cold weather problem)
  4. Number plate light problem
    By namwen in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2011, 19:24
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
