Thread: sidelight bulbs
    Regular Member tiimi's Avatar
    Sep 2012
    anglesey, uk
    Default sidelight bulbs
    one of my sidelight bulbs gone so just gonna replace both, is there any particular good ones which anyone recommends ???
    Regular Member farley2708's Avatar
    antrim n.ireland
    try these mate,nice n white when they light up
    http://www.google.co.uk/url?sa=t&rct...55534169,d.d2k
    Sep 2012
    anglesey, uk
    cheers mate, got them ordered now. are they hard to fit ??
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by tiimi View Post
    Not if your hands are quite flexible. Unclip the back panel (but make sure it's the right one so you don't end up trying to pull out the headlight - ones closest to the radiator) and get your hand in there. You'll feel the main beam wiring and the sidelight wiring. The sidelights are only pushed in so easy to feel. Pinch the back of the connector and wiggle them free. Old bulb out, new bulb in, and turn your sidelights on and look through the lens at the front. Much easier to line the light up that way than guess where it is.
    Easier when you're doing the battery box side if you lift the battery lid up and pull off the washer bottle filler neck. Push the little black clip part out then wiggle it free. It just pushes back in again. Just don't drop the bulb down the hole - put a rag over it or something. Still got a bulb floating round in mine.
    Regular Member VXD NOT VXR's Avatar
    Dec 2012
    Camblesforth near selby
    ive got these fitted to my car there imense only down side is they strobe when lights are off but stop after about 15 seconds.. really really bright..
    http://www.ebay.co.uk/itm/2X-Car-T10...item51a52dfd09
    Dec 2012
    Quote Originally Posted by cont1204 View Post
    or if you have big hands pull out the airbox sounds drastic but i tried for ages trying to fiddle around trying to get light out ended up loseing the light inside the headlight... took ages fishing the ****** out so basicly a 5min job turned into about a hour......
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by VXD NOT VXR View Post
    Sod isn't it. To be honest, it's easy enough to drop the bumper and just unbolt the light units to change them. Saves the scraped knuckles etc.
    Sep 2012
    anglesey, uk
    cheers for the reply guys, ill let u know how i coped wen the new bulbs arrive
    May 2011
    luton
    http://www.ebay.co.uk/itm/Super-Brig...item1e6964be00
    Iv got these ones very bright but they do flicker 5 times n den go off
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    68 SMD's?! Jeebus, are they not a bit bright just for sidelights?
    I have these atm but I've ordered these so they'll be a bit brighter...not lighthouse bright, mind.
  1. M -Tec 501 Sidelight Bulbs
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 20:50
  2. Sidelight Bulbs
    By Tam80 in forum General Motoring Chat
    Last Post: 26th May 2012, 21:51
  3. LED sidelight bulbs/What do you use?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2012, 19:39
  4. 501 sidelight bulbs
    By VectraElite 2.2DTi in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 23:21
  5. M-tec 501 sidelight bulbs x2
    By bobby-tupper in forum Parts for sale
    Last Post: 31st May 2010, 14:24
