Thread: Wireing vectra c tubs
    Nov 2010
    Norway
    Default Wiring vectra c tubs
    I want to connect auxiliary (1000 meter tubs) on my vectra c. What I'm wondering is which wire on the main lantern I should connect control power from? What colur it is on the wire for longlights
    May 2012
    NW UK
    Hi Kosen,
    Check this LINK
    I'm guessing you need the headlight main beam wiring colours? The second post on the link may help.
    Nov 2010
    Norway
    I have 10 pin on drivers side. Sow it is not the corect table.Yes i need the headlight main beam wiring colours for vectra c 2.0 dti spacewagon 2004
    Nov 2010
    Norway
    I have following cabels grey, white green yellow black, black/white and brown x 4
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    high beam should be white wire
    Nov 2010
    Norway
    Are you shure?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes should be white.
    Nov 2010
    Norway
    I have xenon on the lower beam on headlights. And there are as i said ten cabels to the headlight. Not as #bindex`s post with wiring. Where it is only 5 cabels
    Engine : 2.2 Direct
    is still white
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    as per my messages to you its definately the white for main beam
  1. 2.2 DTI Elete engine bay wireing diagram or ecu pin connector
    By Tim C in forum Vectra C / Signum Troubleshooting
    Last Post: 18th August 2012, 12:46
  2. tow bar wireing , useing by pass relay
    By shaney_87 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2012, 21:05
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
