Thread: Passenger footwell leaking, not the scuttle panel!
    Aug 2009
    Kidderminster
    Default Passenger footwell leaking, not the scuttle panel!
    Hi, my partners 02 Vectra Elite has a leak in the passenger footwell, if I take the paneling out then you can see the water dripping from the metal mount point that the dash "sits" on behind the dash. Also the side of the pillar behind the footwell trim you can see the water droplets on it. I have cleaned out the scuttle tray drain under the pollen filter but it still leaks and its driving the other half mad as it makes the car smell any ideas welcome please
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Windscreen seal
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    If its windscreen seal is there a easy fix for this??
    Aug 2009
    Kidderminster
    Ill take the scuttle off and try some silicone and see what the outcome is, cheers
  1. Scuttle panel renewal
    By PeteD in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 09:52
  2. Signum 2006 is leaking, passenger footwell
    By Princess D in forum Bodywork & Interior
    Last Post: 14th October 2012, 12:58
  3. Water in passanger footwell and not the scuttle drain???????
    By dannydoncaster in forum Engine & Drivetrain
    Last Post: 17th June 2012, 12:49
  4. Remove scuttle panel
    By chrish22 in forum Bodywork & Interior
    Last Post: 30th May 2011, 18:01
