Results 1 to 10 of 27
Thread: Facelift Vents in a PreFace ?
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    135 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Default Facelift Vents in a PreFace ?
    Hi guys. Thinking ahead, I'm planning to do something with my Pre-Face 2004 Vectra & NCDC2013 Satnav at some point in 2013. Ideally replace it with a DVD90 if I can find one, but the main problem concerns the vents.
    I'm fairly sure that I could just transplant the screen & centre vents from a facelift, but can anyone confirm that the changeover is a "perfect fit" or does the change require sizing mods to make it fit ?
    Lastly. assuming the centre vents fit ok, can I similarly swap the side vents froma facelift if I go down this road, are they the same size as far as fitting in the spaces on a preface ?
    Thanks for your help
    Full Member witty's Avatar
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    You need to keep the pre-face trim around the vents as the face-lift ones have got rounded corners. The trim just clips off.
    May 2012
    135 Post(s)
    Mileage : 131,000
    Ah but I wanted to fit a facelift set of vents/trims all along the dash (specifically to allow for a screen change to one of the facelift satnavs), does this mean that it isn't an option ?
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    You can change the vents but will have to keep the original trims as the face lift trims are a slightly different shape.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    they are rounded, as witty said just swap the vents to your surrounds, its what I did.
    May 2012
    135 Post(s)
    Mileage : 131,000
    We might be talking at cross purposes here. No point in changing the vents unless I need to in order to accommodate a change of centre screen. However, if I do that, I assume the original vent covers/surrounds would not fit the replacement screen, hence me thinking they would need changing to match ?
    Sorry about the confusion
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The change of centre screen (I assume you have bought yourself a CD70 Navi) means you will need to carry over the vents and vent trim from the facelift. There will be a gap at the corners though.
    I believe YYSNET had fitted the CD70 Navi and screen to his pre facelift.
    Regular Member Vectra_Wilky's Avatar
    West Yorkshire
    I've done this, changed all my prefacelift vents to facelift when I fitted my cd70. No need for cutting or anything they just fit, however they leave a slight gap on the top two corners where the preface were square and the facelift are rounded. Not a major issue. I thought about putting some trim behind but could risk making it more obvious. Hth
    May 2012
    135 Post(s)
    Mileage : 131,000
    So, if I do this mod, I will not be able to have a set of matching left/right side vent covers to go with the centre trim/vents ?
    No worries if that is the case, I just needed to get the info into my head LOL.
    So an upgraded Nav/Info facelift screen on the pre-face will wind up with me having a mis-matched dash trim then ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by woodpeck View Post
    Can you not just get all of the facelift vents (passenger/Centre/driver side) and that way colour will match. I'm not sure how much of a colour difference there is but I think most who have done this mod have swapped all vents over.
  1. preface parts on a facelift question, rear vents and middle headrest
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2013, 20:54
  2. Side Vents for Facelift
    Last Post: 27th March 2009, 17:16
fit facelift cid into pre facelift vent
