Results 1 to 10 of 11
Thread: 2.0 dti started first time, then cut out, wont restart !!
    Oct 2011
    scotland
    Default 2.0 dti started first time, then cut out, wont restart !!
    hi all and a merry christmas !
    first time in 18 months and over 20,000 miles i have had to ask for advise,
    had my 04 vectra 2.0 dti parked up for about 2 weeks (really cold weather), went to start and it started first time , as usual, but then after about 30 seconds, cut out and will not restart, it was a little low on fuel (ie fuel light flashing) but i have been this low before with no problems, put the spare can of fuel in, still would not start.
    initial thoughts after reading loads of posts is the fuel pump, but also read other reasons as well.
    has anyone else had this happen?, no lights show up on the dashboaord, (i dont have a fault code reader)
    any thoughts very very welcome
    best wishes to all, polyroly
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Fill fuel filter to brim. And try again if still no joy.
    If still no joy get some carb/ brake cleaner sprayed into inlet (after air filter)
    if you don't have any then a can of lynx etc may do the trick to get it going to draw enough fuel through.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Buy the vauxhal fuel primer tool, saves soo much hastle for the sake of £15-£20.
    If your near glasgow you can borrow mine (it is in the work tho)
    Regular Member bigdunk1985's Avatar
    Aug 2011
    Ellesmere Port, Cheshire
    Trim : GSI
    Year : 2002
    my 2.0 dti did this when i changed the fuel filter, there's a air lock somewhere in the system
    as suggested above, you will need a fuel primer tool and also fill the fuel filter container full to the brim
    it will take a couple of turns to fire, but it will run..... eventually
    East Midlands
    Fit one of these in when you get it going or before,i used to have the problem your getting,ever since this has been fitted if it wont start just press the bulb a few times to prime the filter and away you go,also avoid parking facing up hill.
    Oct 2011
    scotland
    many thanks for replies, i will have a look for a primer, (my old rover 45 had one ), but when i did actually run out of diesel, it was not powerful enough to get it going so had to go into the garage to have the system bled/repressureised, sounds like this tool is far superior!!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Try getting a tow start if you need it going in a hurry. Sounds like the fuel has drained back while the car has been parked. You'll need a good 1/4 mile tow though
    East Midlands
    ?Have you got the motor started yet...
    Oct 2011
    scotland
    hi, not had chance to even look at it over the christmas period, !!, had the dreaded flu, so not going out , next week looks like a good opportunity, the vecky is mainly our summer car, tows caravan and we go big distances in it, still a boot load of camping stuff in it !, so will have to have a good clear out to access various bits before i retax it, winter time only used on rare occasions, hence parked up, (just wish i had not let the fuel go down so low), you live and learn!!
    Jun 2012
    Northern ireland
    Hi,I had same prob,it's air getting into system ie,through leak off pipes or injector seals which causes fuel to drain back to the tank.leak off pipes are easy and cheap to replace,if your fuel filter is black it's inj seals!hope this helps.
  1. Replies: 9
    Last Post: 1st July 2012, 10:58
  2. Wont start most of the time (fixed)
    By pemtek in forum Engine & Drivetrain
    Last Post: 16th February 2012, 10:46
  3. Engine cut out, won't restart
    By 137mph in forum Engine & Drivetrain
    Last Post: 27th February 2011, 18:06
  4. restart a computer help
    By benny in forum General Chat
    Last Post: 4th May 2008, 12:19
  5. Z30dt Engine Restart
    By daviek in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2007, 15:57
vectra dti cut out and wont start
