Thread: Brake piston/rewind tool
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Brake piston/rewind tool
    Merry xmas guys. Hope someone can help.
    I set out to quickly change my rear brake pads this afternoon as I could hear a sort of rubbing noise of metal from the rear of the car.
    Changed the offside one with no problem but after putting on new pads on the nearside (pads were already low and piston probably fully out) and winding in the piston, the rewinding tool is not coming off when I tried to take it off. Tried as much as I could but to my surprise the lever on the rewinding tool that is used for turning is bending.
    Anyone know why it is not coming off?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Screw/unscrew the part with the nut on it (right hand side of picture)
    easy peasy
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    If the threaded rod is bent you will have trouble removing it without damaging it. From the look of your piston its not fully retracted, shouldn't the piston be hidden by the rubber at a side view like your photo.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by XPCobra View Post
    easy peasy
    Your suggestion makes absolute sense as both the nut side or the threaded side are movable (in opposite direction to each other). Will try this first thing tomorrow and hope it works. Thanks.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by cliomjh 102 View Post
    It is not the threaded rod that is bent. It is the lever handle that is used for turning the tool that is bent. Although the piston might look not fully retracted, I tried placing the calliper in position and there is enough space for it to fit in when the rewind tool is removed. Thanks for the reply.
    Engine : 1.9 CDTi
    As said above....
    You need to wind the larger nut in to release it.
    Try turning the handle as if you were still winding the piston in and turn the large hex bit the other way.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by lee gsi View Post
    As said above....
    Thanks mate. It all sounds and looks straight forward now. Just did not think of that because I have never had to resort to turning the hex bit. Will complete the job in the morning when there is light.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    All sorted guys. It easily came off when the hex part of the tool was turned. Thanks
  1. piston rewind tool
    By brtsam1 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 20:39
  2. Piston Rewind Tool
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2012, 13:07
  3. brake rewind piston tool details
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2011, 10:53
  4. Brake Piston Rewind Tool - Which One?
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 19:17
  5. Piston rewind tool
    By ickleric in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 11:28
brake piston wind back tool vauxhall c
