Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: EGR Re-Mapping Out
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default EGR Re-Mapping Out
    Other than the re-map is there anything else that needs to be done, I will not be taking the DPF out?
    Can it stay in place, it currently has a blanking plate with 3 6mm holes drilled in it.?
    Regards.
    Once it's mapped out that's it mate - you just need to fit a complete blank so no crap gets in, but you can't remove the valve completely as the system still needs to know it's there, it just doesn't open it...
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by Penfold101 View Post
    Cheers for that.
    Will the car still do a re-gen of the DPF?
    I don't see why not - I've no idea if the EGR is involved in the DPF cycle software but I don't see why it would be...
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    You'll find that if you blank/partially blank, or even have a sticky egr valve, your DPF will fill up quicker. It's not recommended to anything to block the egr off unless you've removed the DPF and removed its function from the ECU.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by mally View Post
    Actually thats not quite true;
    With faulty EGR valve (e.g. sticking open) there may be more soot emission due to exhaust gas being recirculated when it shouldn't be (e.g. at full throttle) resulting in an oxygen-depleted intake charge which will cause more soot and hence will fill the DPF more quickly.
    With fully disabled/blanked EGR, there will be LESS soot emission because there is more oxygen in the intake charge. EGR's only purpose is to slow down the burn rate which reduces the peak combustion temperature and hence NOx emissions.
    I've been running with EGR disabled but DPF still working for some time now without any problem - it has regenerated a couple of times without issue. If anything it seems to be going further between regens. I'm planning to remove the DPF in the spring though...
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Why remove the DPF if its running ok?
    Because it's only there as an emissions regulations device, and was fitted because some of the engine/model combinations didn't meet the required levels, ie estates, automatics and Signums. You can find a manual Vectra which doesn't have one fitted but is the same age and engine and gets in under the required level to meet Euro 4 emissions. This alone proves it's just for that purpose, and they weren't fitted to actually do anything useful. It just wastes fuel and causes problems, nothing else.
    Rant over.
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Mileage : 101000
    exactly - it reduces performance and fuel economy generally, due to being a restriction.to gas flow on the exhaust. then to add insult to injury the engine wastes approximately half a gallon of fuel every 500-1000 miles to create enough heat to burn off the collected soot.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    If I unplug tge EGR Valve will the car still perform Regen?
  1. Mapping available for the 2.2 dti?
    By Rickiek123 in forum Tuning
    Last Post: 4th December 2012, 01:23
  2. re-mapping in WM
    By bert3d in forum West Midlands
    Last Post: 24th December 2011, 16:35
  3. mapping out egr
    By iasha in forum Engine & Drivetrain
    Last Post: 19th August 2011, 18:18
  4. re-mapping ?
    By mrk in forum Diesel Engine related
    Last Post: 28th April 2010, 18:43
  5. 3.2 GSI Ecu help for mapping
    By v6-er in forum Petrol Engine related
    Last Post: 15th February 2009, 23:29
how to map out egr on cdti vectra
mapping out egr valve vectra c
map out egr valve vectra
vectra c volumetric efficiency
volumetric efficiency z19dth
how to map out egr valve
how to tell if a egr is mapped out
