Thread: Spare Wheel == Size Question .
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    Default Spare Wheel == Size Question .
    My Renault Grand Scenic
    ( even though , i'm sure it is just a big Megane = L.O.L. )
    has one of those cannister jobs for flat tyres ,
    So i am on the lookout for a real spare wheel
    and i have found a brand new steel one for £ 25 .
    My question ...
    My tyres are ... 205 / 60 / 16
    and the spare wheel i have found is ... 205 / 55 / 16 .
    As a tempory spare would the difference of 5 in the middle number make any difference ?
    Also , where are my jack / wheel brace kept ?
    it's a 7 seat , so they aren't under the boot or in the side cupboards .
    Thanks .
    A spare wheel was a cost optional extra on this model
    You then raise the rear seat to access the retaining strap
    The accessory kit is then kept within the remaining space
    Mar 2011
    Thanks for the reply ,
    but what about the 5 difference in the 2 different wheels .
    Even if i have no spare as an option at the factory , i still need to know where the jack & wheel brace is incase i need to change a bald tyre .
    Many thanks .
    * EDIT *
    just read your comment , so even if i don't have a factory spare ( and have a cannistor ) the wheel tools / jack are still under the back seats ....... are they ?
    South east
    I doubt you have a jack in the car if it didn't come with a spare wheel.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    The Renault ones are gash anyway, I bent one trying to remove a wheel on a mates Scenic, its a folding one, complete waste of time.
    Mar 2011
    [QUOTE=Rebellion;1952144]I doubt you have a jack in the car if it didn't come with a spare wheel.[/QUOTE
    That's a bit rubbish for D.I.Y. tyre / wheel changers .
    Renault can't think that just because you have a cannistor that you never in the future would like to take your own wheel off to do some d.i.y work on brakes or a worn out tyre .
    It's not all about punctures that only need to be filled up with a can .
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by HITFACTORY1403 View Post
    The profile figure is the percentage of the width (alot of people think it's a mm dimension)
    So in your case the original wheel 60% of 205.
    Therefore the difference between the two is 20mm on the total diameter.
    When fitted to the front axle, your car will pull to the side your spare wheel is fitted.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    That wheel and tyre will be more than adequate for a spare regardless of the small difference in wall height as it will only be a get you home wheel anyway and you could always buy another tyre if it bothers you that much, regarding the spare, weren't they mounted underneath on the grand scenic ? If so has yours got a cage/winch for the spare ? If not can you actually fit a full size spare in the car ?
  1. Full size spare wheel.
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 20:17
  2. Spare wheel Size
    By neilrobinson1988 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2011, 11:36
  3. Full size Spare wheel??
    By JamesGTB in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2009, 19:41
  4. Anyone have a full size spare wheel...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2009, 21:17
  5. Anyone in NW got a spare full size 17" Wheel going spare?
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2006, 01:51
