Thread: Noisy rattle
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Default Noisy rattle
    My car beginning to make a rattle noise on idle. If you rev it slightly to 900 rpm the rattle goes away, but once on tick over its quite noticeable.
    Listened under the bonnet, and its coming from the chain area!
    So is it due a chain replacement, or is the chain tensioners not working. ?
    Its had oil changes every 5k with vx oil 10w 40 semi from 25k onwards, now on 119k. So its not down to lack of oil changes, and its not been driven hard, thrashed either.
    What's the likely problem. Tensioners or replacement chain or both?
    Regular Member HenryD's Avatar
    Nov 2012
    cornwall
    First thing I would do is remove the auxillary drive belt and run the engine just to check if the noise is still there,the auxilary belt tensioner could be the cause of the noise.
    Quote Originally Posted by HenryD View Post
    When this bearing fails it gives off a metal to metal noise, rather than a rattle, and although more obvious at idle it can still be heard at all engine speeds
    Nov 2012
    cornwall
    I was thinking more of the tensioner itself rather than the bearing.
    If the tensioner itself had become slightly loose it is possible, but it is more common for the bearing to wear out
  1. noisy cat
    By vectrabtcc in forum Engine & Drivetrain
    Last Post: 15th February 2012, 10:51
  2. Noisy Fan!
    By suresh.chohan in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 20:30
  3. Noisy Top End
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 09:45
  4. Noisy Air con
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 19:19
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
