Thread: Another Z19DTH flat spot/hesitation thread
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    176 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default Another Z19DTH flat spot/hesitation thread
    I thought I might start this thread in the hope some people may find it useful. It appears from my personal experience and time on this forum that there are at least 3 different behaviours on this engine that many people describe with the same terminology, yet they are very different. So I will describe them each below, along with what I believe can be done to rectify them. This is just a start and needs more work - but I hope one day it could develop into a howto...
    Problem 1: No power below 2000rpm
    The exact RPM will vary, but in most cases this fault is identified by an extreme lack of power, then as the revs gradually rise the engine bursts into life at a specific RPM and produces full power, typically somewhere between 2000 and 2500 rpm.
    Cause 1: EGR valve is sticking. This is sometimes accompanied by a spanner-through-car or engine light on the instrument panel, which extinguishes once the engine starts producing power again. Fault codes relating to EGR flow/performance may be present. Unfortunately in the early stages of this fault, there may be no lights or fault codes present.
    Solution 1a: Remove and clean the EGR valve as described in the howto. If this doesn't work then further diagnostics and potentially a new EGR valve may be required.
    Solution 1b: The EGR valve can be disabled in software and optionally 'blocked up' with a metal blanking plate. The software part can be done by a tuner, and may also include a performance remap. Note: Blanking without disabling in software will cure the fault but result in a permanent Engine light on the instrument panel.
    Cause 2: Swirl valve mechanism stuck/broken
    I think most people on the forum are familiar with this one. The bar linking the swirl flaps on the intake manifold will often be detached. Typically this one will not cause any fault codes or warning lights.
    Solution 2a: Replace the complete intake manifold (time consuming and expensive), or effect a temporary repair as described in the howto's.
    Problem 2: Momentary hesitation at around 2000rpm
    When full throttle is applied at around 2000rpm the engine will offer a surge of power, followed by a momentary loss of power for 0.5 to 1 secs, then resume normal accelleration. It is as if you had lifted your foot off the throttle pedal for a moment and then re-applied it.
    Cause 1: Boost pressure control solenoid slow to operate or split vacuum pipes
    Solution 1a: Check condition of, or replace all vacuum pipes between the vacuum pump and boost pressure control solenoid, and the vane actuator in the turbocharger.
    Solution 1b: Dismantle the boost control solenoid and clean the filter as described in this thread: http://www.vectra-c.com/forum/showth...dti+hesitation. If no cure, then try replacing the solenoid.
    Cause 2: Variable vane actuator or mechanism sticking
    Solution 2a: Log data using opcom or similar tool and look for boost spikes. If boost spikes are present after solutions 1a and 1b have been completed, it may be necessary to have the turbocharger inspected and possibly reconditioned/replaced.
    Cause 3: Software fault
    Some software versions had the boost pressure tolerance (PCR Governor) values set to tightly. Although these values were ok when the engine and components are new, normal wear and tear which results in slightly sluggish operation of the VNT control vacuum/mechanical components can cause the PCR governor to over-compensate resulting in this hesitation.
    Solution 3a: Later software versions appear to have a larger PCR Governor window size, which cures this problem. I don't know when GM changed this as I have only compared two cars - one was last updated in 2005 and had the 'problem values', the other was updated in 2008 and has the 'corrected values'. If you have the opportunity, get the software updated by a vauxhall stealer. Or a competent tuner should be able to change these values along with other useful changes such as egr disablement and a performance remap.
    Problem 3: Turbo Lag and high boost threshold
    This is not a fault per-se, but rather an inherent characteristic exhibited by all Z19DTH engines, that many people complain about even when the car was brand new. Basically there is very little power below 1500rpm (boost threshold), and when throttle is applied suddenly between 1500 and 2000rpm it can take a couple of seconds for any useful power to develop (turbo lag).
    Cause: The high boost threshold appears to be caused primarily by the sub-1500rpm torque limiter values set in the software, which are very conservative and actually much lower than the Z19DT engine as can be seen in a side-by-side comparison in the screenshot below:
    I am not sure why GM have chosen to set the limit so low on the Z19DTH engine - perhaps something to do with emissions? If it was to protect the DMF, I would expect both engine types to have equally low values. The second part of this problem - turbo lag - is caused by the values in the smoke limiter map.
    Solution: A tuner will be able to change the torque limiter values to improve the amount of power available below 1500rpm. They will also be able to alter the smoke limiter map to reduce the turbo lag (perhaps less so on DPF equipped cars though). On mine I've altered both and the difference it has made is incredible - although I fear for my DMF and may back-off a little. But setting the 1000-1500rpm values to the same as a Z19DT should be safe.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Well done and very nice post thank you.
    Have a look at the AR 1.9JTD mapping for comparison values also.
    I'm interested in what you see there, you might be too
    I'm away for Christmas so no files here to help.
    CHESHIRE
    found the part 3 very interesting , wonder why vauxhall have lowered the torque values on the cdti 150 before the turbo kicks in ?..
    Kent
    Great information there mate.
    I have noticed this sub 1500rpm "turbo Lag" on my 2008 1.9CDTi 150. Mine is auto and the lag when you want to get a quick getaway when entering a roundabout from standstill is quite frankly Bl**dy awful. It just wont pick up. I have had the EGR removed and cleaned about 200 miles ago and its no different.
    I am wondering whether there is anything I can do to make it more lively and less dangerous??
    Any ideas??
    Paul
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Boost control valve will need sorting as can stick. I'm doing mine soon to take apart and clean.
    One other way to get that spot sorted is a remap. DPF have a role too which makes it a bit of an issue of blocking up thus blowing away is a bit harder, so i'm having a remap removing dpf, egr and adjusted to give better torque/hp and mpg!
    woodbridge, suffolk
    176 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by Pepsi Max View Post
    Any ideas??
    Paul
    Really the only way to solve this is to remap it, as I have done with mine. I've been playing for a while and made quite a lot of modifications to the mapping of mine - but increasing this torque limiter made a huge difference to the sub-1500rpm acceleration. I wish there was a way to find out why GM set the torque limiter so stupidly low on the 150 in the first place...
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Well done mate
    A very good wright up there
    Merry Christmas
    Your info is very useful
    woodbridge, suffolk
    176 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by C-Owner View Post
    Hmm, looks like I'll have to do some digging on the net for a JTD ori file then...
    woodbridge, suffolk
    176 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by Humourbash View Post
    Yes the DPF doesn't help matters. I still have the DPF on my Signum Z19DTH. With raised torque limit it is now a lot better at low revs, but still not quite as good as our Vectra, which has a Z19DT engine and no DPF.
    Also with DPF fitted you can't be so 'generous' on the smoke limiter maps, so you will always have more lag on a DPF equipped car. If you change the smoke limiter maps too much on a DPF equipped car, you risk filling the DPF up before the ECU calculates it to be due for a regen. The regen intervals are purely based on statistical modelling - contrary to popular belief the pressure sensors on the DPF play no part in deciding when a regen is due. So if you change the mapping to allow a richer AFR and hence more smoke, then the calculations will not match reality and the result will be a dead DPF.
    So in summary; to get the best performance gains at low RPM through remapping, the DPF needs to be removed like you suggested :-)
  1. think i may have finally cured the famous flat spot hesitation,read on....
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 20th April 2014, 21:19
  2. z19dth totally flat in power
    By RyanNI in forum Engine & Drivetrain
    Last Post: 25th November 2011, 09:17
  3. Replies: 0
    Last Post: 8th August 2011, 16:39
  4. Flat Spot/Stutter or hesitation on 2006 1.8 VVTi SRI
    By Fireyfella in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 08:30
  5. flat spot/hesitation
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:53
z19dth boost control solenoid
z19dth no vacuum to solenoid valve
vectra c stuttering at low revs
z19dth not boosting
z19dt hesitation
z19dth turbo
z19dth boost control valvez19dth turbo control solenoid cleaningz19dth engine flat spotvectra z19dth hesitationz19dth no boostz19 dth flat spotvectra c boost control solenoid cleaningvectra c lags below 2500 revsz19dth remap filez19dth turbo lagwhat should a z19dth boost pressure bevectra c 1.9 flat spot at 2000 rpmZ19dth laggz19dt vacuum pump to boost solenoidvectra acceleration hiccup at low revsz19dth full throttle stallingZ19dth hesitationcure boost spike on z19dthbuy z19dth boost control solinoid
