Results 1 to 3 of 3
Thread: how much boost
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default how much boost
    ok, been playing with my torque pro app, and was wondering..
    what psi should i be seeing from the turbo in psi on say idle and crusing at 60mph about 2000 revs. ive got an auto so the revs dont get very high but was just wonderig what sort of figures i should be looking at. on idle mine sits at about -0.7 to -0.1 psi
    its a 2.2 dti btw
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd be very surprised if it was getting the correct readings with it being a DTi. They're known to be very hard to talk to. Idle, nothing really. With it being a diesel with a vacuum pump it can't actually have a negative boost pressure because it doesn't have a throttle body. It's essentially always wide open. Engine speed is controlled by the fuel being injected. Full boost (from memory so don't quote me on this) would be about 14psi. Cruising the engine is again hardly working so about 5 or 6 psi, maybe a little more or less depending on the road.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Which is near enough what im getting. Thanks for that
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
