Thread: new battery in but now starter does not turn all other elecs appear OK bat shows 12.5v
    Nov 2009
    Croydon
    Default new battery in but now starter does not turn all other elecs appear OK bat shows 12.5v
    Hi
    I hope I am posting in right place now. My car is a 2004 19.cdti vectra My battery was getting gradually worse so replaced it today with a 75ah bosch silver battery. Once all connected up the car started fine I then turned off to tidy things up and had a bit of trouble getting the protective jacket over the battery then when all sorted went to start it again and nothing
    The ignition comes on but when you turn the key there is nothing no attempt for the started to turn although there is a very faint click but not like the starter trying. The battery displays 12.5 volts when I put a meter on and this does not drop when I try and start.the car
    I am wondering if I dislodged something when I was putting the jacket on but can not see anything obvious or if I have blown a fuse somewhere. As far as I can find out although this battery is more powerful than the previous one it should have been OK as 3 retailers recommended it. There is a big fuse on the LHS of the battery compartment but this looks OK
    Does anyone have any ideas what might be wrong or know where the solenoid for the starter is in case I can check this
    Any help would be much appreciated especially as I am not likely to get a garage out easily before Christmas
    Regards
    Dan
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    First route for me would be checking all fuses and for loose/dislodged connections in the area around the battery before trying to start but using a booster pack or a jump to ensure enough juice.... new batteries are 'flash charged' but should be fully charged prior to sale/fitting.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check batt connections again
    check all your fuses.
    if it started and now doesn't it'll be something simple
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Could be you had a bad connection somewhere all along (even before new battery) and have now fully dislodged it. The clicking is the starter relay (solenoid) but sounds like the main fat cable that goes to the starter has a loose connection somewhere.
    How old was you old battery ?
  1. Replies: 14
    Last Post: 25th December 2012, 17:48
  2. Replies: 6
    Last Post: 23rd December 2012, 21:16
  3. Vectra C battery discharge and OBC shows error in sensor.
    By jyot in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 15:16
  4. starter motor ,battery or ignition or anything else
    By tyler boy in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 19:24
  5. Replies: 14
    Last Post: 25th August 2006, 00:04
