Thread: Climate control panel removal help
    Jan 2008
    Gloucestershire
    Default Climate control panel removal help
    Hi, how on earth do I get this out ?
    http://i306.photobucket.com/albums/n.../DSC_00032.jpg
    I've prodded and pulled but it moves not ! Reason is I want to give the central switch a bit of a look at as often I cannot switch from eco to CC mode.
    Ta, and Merry Xmas all.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i tend to remove the ashtray and its trim plus fag lighter, i then pull out the storage tray below the ECC panel this then enables me to get a good grip on it to pull it out
    Jan 2008
    Gloucestershire
    Quote Originally Posted by Caveman_nige View Post
    OK thanks - so it is just a "pull" there are no fancy clips or catches... I'll give it a go ! Been driving me nuts on and off for years - I'll make it an Xmas break job if the rain ever lets up.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    last time i took mine out I eased a small screwdriver down the side then gently popped it out , mine also had the centre button fault , quick re-solder & its all ok now
    WGAF#5
    As Nige suggests the easiest way to remove ... And yep it just pops out
    Jan 2008
    Gloucestershire
    Quote Originally Posted by DTi Elite View Post
    DTi - oh - think that's a tip - I was thinking that it was likely to be crud needing a dose of switch cleaner - Will fire up the iron as well.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    just hold on to the knobs and just pull towards you.
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    Wrap some strong masking tape around the shaft of a screwdriver so it doesn't mark the fascia to the sides of the unit, leave the tip clear and ease in gently to avoid scratching it.
    Nov 2012
    Birmingham
    As DTI elite said, I did it exactly the same. It just pops out.
  1. If I fit the climate control panel....
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2012, 12:51
  2. climate control panel not working
    By mikeeaston in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:53
  3. Climate control panel fault
    By MadOnVaux! in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 17:45
  4. Climate control panel
    By jujitsuboy69 in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2008, 10:37
how do you remove the centre control panel on a vauxhall vectra c 2007
vectra c remove control panel
How to remove a vectra c heater control panel
vectra c climate button removal
vectra c climate control panel
how to take out heater control panel vectra c
2005 vectra elite climate control
vectra c elite air con button
vectra c climate control button
how to remove heater controls on a vectra
how to remove vectra c heater control panel
remove heater control vectra
how to remove heater controls vectra c
