Thread: An Old Trick That Really Works
    South east
    Default An Old Trick That Really Works
    Friday afternoon and I find myself changing the wheel on a friend's Ford Ka (don't ask...lol) due to a puncture, and like many poorly maintained cars the wheel wouldn't come off once the car was jacked up and the wheel nuts removed. As I was using the weedy Ford jack and not axle stands, applying more than moderate force to the wheel to free it wasn't an option, so I used a trick I've read about on here - put the wheel nuts back on, leave them a little loose, lower the car back down and start the car and drive it a few feet. This should cause the wheel to free itself. In fact, if the tyre you want to remove is flat and is on the front, as in this case, you don't even need to move the car back or forth, just turning the steering wheel left and right will do the trick because the flat tyre is reluctant to move and thus tries to resist the swivelling movement of the hub.
    My point is, it really works, and takes just a few minutes of effort (lowering the car and then jacking it back up again), so if you find yourself in a similar predicament, try this rather than resorting to bashing at the wheel/tyre with a hammer.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I just kick the top of the wheel lol that soon gets it off.
    Sodding Typical on Sea
    Indeed a great tip. I have used this myself when the alloy rim "welds" onto the steel of the hub. I routinely use coppergrease to prevent this.
    Full Member witty's Avatar
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    Quote Originally Posted by Derek Mc View Post
    I also use copper grease every time the wheels are off...
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I just kick it too lol...
    South east
    I'd kick it if it was on axle stands....maybe even on a trolley jack. But not on one of those spindly jacks that doesn't even stand upright unless the weight of the car is on it, which is even worse than the scissor jack you get with a Vectra.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    lol a trick ive seen used before, and very useful.
    Mileage : 000
    I lowered my car to the ground a little just enough off the ground so that when I used the ground as a slide I whacked a hide mallet against the and the wheel soon came off. Obviously leave two wheel nut on loose though.tyre
  1. Pedal trick
    By 123ashleyp in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2010, 03:47
  2. And for my next trick..........
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 21:05
  3. fantastic trick
    By yorkshireborn in forum Comedy & Humour
    Last Post: 23rd March 2009, 20:39
  4. Trick or treat...
    By AndrewTi in forum General Chat
    Last Post: 1st November 2007, 21:45
  5. Gordon's trick
    By Doug-SRidirect in forum Comedy & Humour
    Last Post: 2nd February 2006, 14:14
