Thread: Overheating Z22YH!!!!
    Dec 2012
    Sweden
    Default Overheating Z22YH!!!!
    Hello,I'm having big issues with my 2.2 vectra.
    Driving home from work this Friday I noticed all of the sudden that cold air was blowing through the vents even though the panel was set on a high tempeture, well the the hot air came back and then disappeared again and the I noticed that the temp gauge went up over 90c and continued rising too over 100c. It went up so much that the temp warning light started flashing and I had to pull over and cut the engine.
    Had a hell getting home with all the starts and stops.
    So yesterday I changed the thermostat hoping this would help, well now I doesn't go to 120c, stops at approx 100c. But still no hot air coming out of the vents.
    I have topped of the coolant expansion reservoir, hoping to get out the air... And the thing is that I have a gas warmer on my car, I live in Sweden so it's needed due to the fact that at this moment we have -12,6C. Well this gas warmer has a external pump that pumps around the coolant as the warmer heats it up, and as the car hits approx 100c and i start the warmer and the pump starts working and circulating the coolant then the engine temp drops and warm air starts coming out of the vents...
    So could the water pump be done?
    How can I check if it's working or not?
    If its a air lock, how can I get the air out....
    Really glad for all the help I can get on this because it's driving me crazy!!!
    Merry christmas by the way!!!
    Best regards
    Sam
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Water pump by the sound of it mate
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    Quote Originally Posted by tony-1977 View Post
    What he said sounds like the water pump is seizeing
    Dec 2011
    Seaham
    Try taking the thermostate out and testing it, it may have stuck shut.
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Do you have ECC ? if it fails, it will stop heating and cooling inside the cabin.. then you only get what outside temperatur you got..
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  3. overheating
    By jonesey42 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:24
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
