Thread: Signum vrs Vectra Headunit
    Dec 2012
    Glasgow
    Default Signum vrs Vectra Headunit
    I recently just picked up my Signum Elite in replacement of Vectra SRI
    However the Vec I owned had a (semi)coloured screen for Satnav & also could show the map in splitscreen from the direction arrow.
    The signum one is an all-orange screen with no colours, is this a lesser model of headunit and is the screen changeable or do I need to change the full unit?
    What model is the highest of headunit? As you would think with the Signum being the Elite (highest model?) it would come with the better satnav/headunit/screen.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    not nessisarly, the elite comes with more wiring so it will be esyer to add extras ure self, the screen is easy enof to change but u need to un pair ure headunit/screen and get an unpaired colour screen then pair it.
    I see u are in glasgow, if u can get a unpaired screen i will sort the rest for u if u want? changed the screen on mines to the one u have now as i am going to get an after market dvd/sat nat unit.
    Dec 2012
    Glasgow
    Ah that would be perfect!
    I'm sure mine is a CD70, shall check when i'm next out at the car as I also read a thread a few posts down about someone getting TV on their CD70 screen.. forward planning & all that!
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Some would say that the CD70 is the top Full-canbus HU (except for the DVD90, but i dont think they exist as no-one has ever seen one). However it depends what you want. I'm currently in the process of 'downgrading' to a CDC40 as i want DAB, which isn't an option on the CD70.
    When you say semi coloured screen, i presume you mean CID. It is actually full colour, as with a few mods you can actually run video through it. You can run a CID with a CD70 or a CDC40 (not sure about a CDR2005) but as Rozzer said you'll need to divorce your gear and make sure the CID you get is divorced from the donor car. If your car is half canbus then you'll need a NCDC 20** HU to run a CID i think but the CID for the half canbus vehicles is different to the full canbus ones and is quite rare.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    What year is ure signum?? the screen is an independent unit, you dont even need a head unit for it to work but u will loose the sat nav and radio options but u will keep ure time date and engine and other funtions like TPMS or cilmate control. You should be able just to get a screen if not u could buy a set and aell ures as a set. The other options is keep ure screen which is a GID and change its colour and get a DVD sat nav after market unit that is taylored to the car so it looks like the one u have with a screen and it has canbus functions but I belive some of them work better than others so that is work looking out for.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    take a pic of your dash to show us and that way we can tell you what you need to know
  1. Vectra Aftermarket Headunit Help
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 21:35
  2. Vectra Headunit Enquiries
    By rcarlile23 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2007, 15:23
