Results 1 to 10 of 25
Thread: Scuttle tray! Doh! Heating packed up.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Default Scuttle tray! Doh! Heating packed up.
    Hi all. During the recent downpours a lot of water has come into the passenger footwell. I have checked the scuttle tray and it was blocked. I have cleared this and now the heating does not work. I have searched the forums and found some helpful posts.
    I have not checked if the motor is seized but I will do this today. What I want to know is, is the resistor pack the same for my car as I have the 7 speed climate and not the 4 speed manual. If it is great if not I'm not sure what part to get. Is it an easy fix. Many thanks.
    Feb 2012
    Luton
    Forgot to mention when I try the climate there is a ticking noise coming from behind the dash somewhere.
    Feb 2012
    Luton
    More digging and its a totally different resistor. Non climate around a tenner. Climate looking at £130 ish. I heard you can buy a cheap thermal fuse for the standard one and adapt it. Can this be done to the climate resistor? Font fancy spending £130 this close to Xmas :-(
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    its more on a control module on your one rather than a resistor... your ones normally burn out to a crispy pcb...
    the clicking noise you can hear (probably when u first open the car doors in the morning as well) is one of the recirc motors with a broken tooth trying to turn.
    Feb 2012
    Luton
    Do you think I would be inline for a motor and resistor then. More money I presume.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I have the complete climate heating unit taken from 58 plate, what parts u want? I wont ask for loads! Just want space back. Cheap!!
    Tell me a part and a price. I promise i'll be cheap!!!
    Feb 2012
    Luton
    Hi. Untill I investigate further which will be around midday today in not 100 percent sure. I will try and find out and I will pm you ASAP. Many thanks for the replies . Speak soon
    Aug 2012
    sunderland
    i have the same problem i thought i had fixed it with a part from the salvage yard about a month ago but its packed up again ..i was wondering if u can just buy the little resistor piece from someware and solder it in???????
    searching the forums now
    if anyone has a link that would be good.
    Aug 2012
    sunderland
    is the little bit on the top of the resistor pack called a "diode"can u purchase just this part?
    Feb 2012
    Luton
    Can this part be bought for the climate 7 speed version as the resistor is different from the manual heating. The climate version is in a silver casing and it also costs over 10 times the amount of the standard manual one!
  1. poll:has everyone cleaned there scuttle tray out lateley
    By vectra ste in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2017, 17:42
  2. Pollen filter swap / Scuttle tray cleaned
    By Envy in forum General Motoring Chat
    Last Post: 28th April 2012, 14:11
  3. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  4. Dpf has packed up
    By ANDY W in forum Engine & Drivetrain
    Last Post: 10th August 2009, 17:53
  5. sky+ just packed up
    By coylo5 in forum The 'Off Topic' room
    Last Post: 7th August 2009, 10:44
