Results 1 to 2 of 2
Thread: p0337 fault code crank sensor position a low>
    Regular Member rickyroo's Avatar
    shropshire
    Default p0337 fault code crank sensor position a low>
    After an intercooler pipe fell off new year I had a "ding" Ding ding noise from engine. it's been popping from exhausts on idle if you blip throttle pedel.
    Vx had it 4 times said couldn't find a fault.
    The car "hunts" on idle and after leaving it running for five minutes or even after a run once engine is turned off the car sit's their and cooks, go back to the car after say 5 minutes the temp gauge will be at 3/4 even if it was at 1/2 or 1/4 hot.
    Finalilly after taking it on a long run to devon they had car in monday fault code P0337 Sintra code 00 is locked into ecu?
    Garage machanic is baffed as didn't have engine management light up?
    Faults been logged with Vx and they are also at a loss.
    The garage has checked fan, sensors crank markers, all o.k.
    Bit worried that maybe bsr ppc caused damage, don't think so but garage said for me to drive it for a week then bring it back to prove a point?
    Wouldn't say what the point is though?
    Anybody got any ideas.
    I think ecu could be f**ked as popping/backfire oni dles always their but the fan works intermitantly.
    Help.
    EVERYWHERE
    Hope you got it fixed mate.Maybe we shouldn't mess with our 'brains'.
  1. Fault Code P1125 for both 1.9 CDTI's - Throttle Position Sensor
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 25th August 2013, 17:54
  2. MAP sensor fault code
    By cus2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th August 2012, 08:22
  3. Replies: 2
    Last Post: 24th June 2012, 02:11
  4. Fault code 0340 Cam sensor malfunction
    By otto in forum Engine & Drivetrain
    Last Post: 28th June 2010, 13:55
  5. 2003 2.0dti, Where does the crank position sensor read from?
    By Neil.b in forum Engine & Drivetrain
    Last Post: 5th January 2009, 20:16
P0337 crank hast
