Results 1 to 10 of 13
Thread: Intermittent spanner light 2.0 t
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Default Intermittent spanner light 2.0 t
    As above the spanner light randomly comes on it feels like its when the car is on boost at high revs it seems to stall / stutter then carry on running but seems to lack power. Once the car has been stopped and restarted the fault vanishes I've had the code read but nothing is present except once I got one that mentioned the turbo wastgate regulating valve. A I've just changed the turbo I've checked all pipes / wires and all seems in the right place . Is the above mentioned part the black box that sits on the top left of the turbo with pipes and a wiring block attached to it ? Is there anyway of testing it thanks in advance .
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    it could be that at fault, its the charged air bypass valve aka boost solenoid.. you have two, one by the turbo and another under the engine cover near the throttle body.. they have different part numbers.
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Thanks for that ive just had a look at it in the garage theres no numbers on it you wouldnt by any chance know would you
    Jun 2009
    South Coast
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    cheers for that you wouldnt happen to have a ball park figure on the price i bet its stealer only aswell there 2 on ebay but rather buy new than second hand
    Jun 2009
    South Coast
    They are not expensive, I have spare I carry in my car but they came from a saab at a scrappy. I think they are about £17 each but need to ordered.
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    I've now changed the boost solenoid for one that was known to work but..... It's still the same anyone any ideas what else it could be its driving me nuts one minute it's driving fine then there's a slight pause then no boost ?
    Jun 2009
    South Coast
    did you clear all codes or reset the ecu after changing it.. if not and you do not have a code reader you can do this be disconnecting your battery for 15mins or so..
    I would try this first before spending out on a new part, its best to do this when replacing any part that throws error codes and LHM..
    your working your way through a process of elimination, the other solenoid is next be changed, after that its your wastegate diaphragm.
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Yes cleared the codes I've got access to a snap on reader . Something I noticed was that on the old valve when removed I couldn't blow through the metal end but on the new one I could ( if that makes sense ) ill try the one on the throttle body in the morning.
    Jun 2009
    South Coast
    I have just checked mine and i can blow through both from the metal end
  1. intermittent spanner light
    By dervb in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 26th June 2012, 02:01
  2. intermittent spanner light
    By dervb in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 23:10
  3. Intermittent spanner light
    By ScubySteve in forum Engine & Drivetrain
    Last Post: 20th February 2009, 17:47
  4. Help intermittent spanner light
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 21:20
  5. Juddering and intermittent spanner light
    By matth42 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2008, 01:53
