Results 1 to 10 of 21
Thread: petrol/lpg cold starting
    Dec 2012
    north wales
    Vehicle : vectra
    Trim : estate life / gas
    Engine : 1.8xer
    Mileage : 184000
    Default petrol/lpg cold starting
    just got a 1.8 07 lpg estate starts up 1st time no problem but i have to let it warm up on petrol if i try to to pull of before its got some heat into it, it will die and be a pig to start once its warmed up then changed onto gas it will run brill sorry if this has been covered already cheers
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    135 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    All LPG's need to start on petrol. They only switch to LPG when the system is satisfied that the engine is warm enough
    May 2012
    135 Post(s)
    Mileage : 131,000
    By saying "all", I do of course mean dual fuelled petrol/lpg motor cars , I exclude specialist motor vehicles like fork lift trucks etc.
    Full Member
    South West
    Most LPG ecu's are set to switch when engine temp gets in the region of 35c
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    mines the same fella. dont let it worry you. if im in a rush then i just switch it to petrol and drive off. but if i have time on my side then i will always wait for it to switch over to gas. something to do with the car getting to the optimal temp. you will notice it switches alot faster in the summer.
    Dec 2012
    north wales
    Vehicle : vectra
    Engine : 1.8xer
    Mileage : 184000
    the problem is when it is on the petrol it wont pull off just dies then a pig to start
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    time to get it on diagnostic & read some live data , maybe coolant temperature sensor out of range or something along those lines .
    May 2012
    135 Post(s)
    Mileage : 131,000
    Quote Originally Posted by murt690 View Post
    Ahh, I see. So basically you can't run it on petrol at all ? Not even when warm ? Did you try to set it back to petrol manually, switch ignition off, remove key, and then start up again without it even trying to use lpg ? I'm not sure if yours is a factory fit lpg or not, if aftermarket, it will definitely have a switch that not only toggles between lpg and petrol, but which also shows how full the lpg tank is. I'm talking about setting it back to petrol completely and try driving it. Does it perform exactly the same ?
    Dec 2012
    north wales
    Vehicle : vectra
    Engine : 1.8xer
    Mileage : 184000
    it is an after market kit it will start up 1st time on petrol from cold ie been stood all night but you have to let it warm up before pulling away or the revs just drop and struggle then it will stall then just turns over and eventually fires but you have to rev it to keep it going bit of a pain when you come to a junction trying to clutch brake and rev at the same time this is still when it is on petrol as the gas has been switched off cheers for the help
    May 2012
    135 Post(s)
    Mileage : 131,000
    Ok, when did you last have the car serviced and when was the last lpg service done ? Do you have the spanner light showing on the dash, or any other dash lights showing up ?
  1. cold starting problem
    By iansfocus in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd February 2011, 16:54
  2. Starting in the cold
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:15
  3. Problems starting 2.2 petrol in cold
    By phil_l875 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 13:45
  4. Bad Starting From Cold
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 7th October 2008, 11:48
vectra 3.2 cold start
