Thread: Need help with strange noise
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Question Need help with strange noise
    So, over the last week, the car has had a distinct knock and rattle coming from the drivers side when going over rough ground. We gave the car a thorough going over this morning, finding that the driver's side banana arm was shafted (movement in wheel). This has now been replaced, and the knock has gone.
    But, there is a rattle/noise that seems to get worse with speed, but quieter when braking. It is coming from the driver's side again (rear), and can be heard occasionally on smooth ground, but a lot worse on the rough. Sounds like something dragging along the ground.
    We've checked everything....
    - All bushes have no free play
    - Ball joints / track rod ends have no free play
    - Anti roll bar has no free play
    - No snapped springs
    - No play in bearings
    - Brake pads sitting nice in the callipers
    - Exhaust and heat shields secure
    - Engine under tray secure
    - Shockers not leaking, not creaking when bounced
    - Car goes straight when let go of steering wheel
    - Does not pull either side when braking extremely hard
    Out of ideas now. Does anyone have any further suggestions?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Looks like this may be the cheap rear brake pads?
    If I pull the handbrake up by one notch, the noise vanishes
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Found the noise. Rear brake pads rattling in callipers.
    This morning I have removed them, cleaned and re-assembled. The top and bottom of the pads that locate in the callipers is slightly different to VX pads ( I used cheapies), causing the rattle.
    Looks like a trip to VX next week for some pads
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    glad you located the problem mate, not too expensive either if you go for gm pads.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Will do discs as well while I'm at it I think
    May 2012
    northumberland
    ah a trade club disc n pad set it is then lol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Trade Club pads.
    Can pick discs up at ECP cheaper than VX with online discount code
  1. strange noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 14:00
  2. Strange Noise
    By fattony in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2011, 14:24
  3. strange noise
    By trev16185 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2011, 08:27
  4. strange noise
    By chrosty in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:20
  5. Strange Noise
    By spennny in forum Engine & Drivetrain
    Last Post: 29th June 2008, 19:32
