Thread: Rear caliper refurb kits? 292mm
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Question Rear caliper refurb kits? 292mm
    My rear 292mm calipers stick on momentarily after I release the handbrake, its mainly after its been parked up overnight. It does not seem to do this after its been standing in the car park during a work day etc..
    Are my calipers seizing, will a refurb kit sort this put or is it likely to start again in a few months time? I am toying with just buying a replacement new calipers but am willing to consider a refurb kit if they are worth the money..
    Anybody got any tips or links?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    This happened with mine. Exact same symptoms.
    We removed the calliper (leaving the flexi-hose attached), and cleaned up the slides and bolts with plenty of brake cleaner, applied plenty of grease and copper-slip on re-assembly, new set of pads.
    The piston was wound in and pushed out a couple of times to ensure it was free.
    Been fine since. Huge difference in that the car now rolls when the handbrake is released in the morning. It never used to.
    Cost me nothing except the time of me and a mate (2 hours).
    Give it a try, nothing to lose
    Jun 2009
    South Coast
    I guess I have nothing to loose trying this as you say.. Lets face it i am not likely to get a new caliper or refurb kit delivered this side of chrimbo anyway. I will add it to my to do list for when it actually stops raining.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I have a piston and seal kit for one side Nige and for info the 292 and 278mm piston and seals are the same thing.
    Jul 2011
    UK
    Year : 06
    I had same problem caliper was dead on the front I got a caliper brand new from car parts conextion it came and was the wrong side even tho the box part number was right I paid 20 pound and basically all I done was take the piston out and clean up the old caliper and fit the piston and seals good as new works perfect and has ever since
    Jun 2009
    South Coast
    wanted to do this today but the wife is out on the lash with her mates and I have the nipper demanding me to build things with lego and help her with her colouring in.
    Paul, are you wanting to hang on to the kit, I am not saying i need one but if i get part way through a strip down on one of the calipers and it becomes obvious its needs new seals I may come a begging so that i can put the car back on the road etc?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You can have it at yours in case you need it mate no problem
  1. Replacement GSi brake caliper (292mm discs)
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 12:31
  2. GSi rear caliper refurb..
    By TimTay in forum Suspension, Wheels & Brakes
    Last Post: 26th September 2011, 21:43
  3. 292mm caliper carriers - Rear Brake upgrade
    By parapaul in forum Parts for sale
    Last Post: 28th June 2008, 09:56
vectra c gsi rear caliper refurb kit
caliper refurb kit vectra c
