Results 1 to 10 of 15
Thread: new/old spare key
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Default new/old spare key
    I bought a second hand key,all numbers are the same except mechanical number
    before I go see if I can get a blade cut am I going to have issues
    I have the unmentionable software to code to the car
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    140 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Yes you will have "issues", you will not be able to re-program a used key fob from another vehicle to your car
    May 2012
    140 Post(s)
    Mileage : 131,000
    LATE EDIT - Sorry, I should have added that you won't have any luck re-programming it UNLESS, you get it "virginised" first. The programmable chip needs to be replaced so that any electronics that you attach to re-program it with, will then see it as a brand new fob. I can recommend someone who can do this if you want, but it will add around £15 (ish) to your costs.
    Woody
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Apparently it can be done with both pass codes and Tech 2 but the genuine vx fobs are fixed together very well and mine broke when I was trying to change the case. It's much simpler although more expensive unless you have both pass codes and tech 2 to buy a genuine one.
    Admin plasma's Avatar
    On the Forum
    315 Post(s)
    Engine : 150
    Mileage : 74000
    as above, BUT both car passes, needs to the key unprogrammed with it in the ignition from the old car and then vauxcom to code it to the new car, its been told to me this is how its done, but not had the chance to try it myself
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jun 2012
    lancashire
    I cant find anyone who can cut the key anyway lol and I dont know if the key has been removed from the previous car so looks like I wasted some money
    May 2012
    140 Post(s)
    Mileage : 131,000
    Quote Originally Posted by john norris View Post
    As said, £9.95 - http://www.ebay.co.uk/itm/GM-OPEL-VA...item564f58e7c8
    Key fob virginising - I can give you a contact, but again, as said, around £15 (ish)
    Jun 2012
    lancashire
    Quote Originally Posted by woodpeck View Post
    yeah please if you can pass on the details I will look in to it
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    John see if you can get it apart first as I said mine was damaged as it was put together by vx by a strong bonding agent and you will need to separate it to get a new blade in I have a spare blank blade flip type if you need one.
    May 2012
    140 Post(s)
    Mileage : 131,000
    I will PM you the contact John. Anyway, irrespective of the route you take, you are still going to need to get a blade cut and I doubt it will cost you less than £9.95 either way to simply "cut only", or "supplied and cut". In any event, you can't go far wrong by having a conversation with the guy, I mean he might even be prepared fit a freshly cut blade to it while he has it apart.
    Unfortunately for us, all of these flip keys look the same from the outside, but there are a few differences between them in respect of the internal electrics. From experience, I got an "identical" key virginised, but it was a different circuit board to the one designed for my Vectra, and as such, on reprogramming to my car, I could only get the immobiliser part to function and start the car, I wasn't able to get the fob remote functions to pair up with my car. Oh well, a lesson learned from my point of view at least.
    Anyway, to avoid any rule breaking or unintentional advertising, I'll pm you the contact details now.
  1. Anyone got a spare 19" snowflake spare
    By pagey_sri in forum West Scotland RO - Mr Gee, ARO - RBH
    Last Post: 1st June 2012, 17:00
  2. Spare Key
    By georgie in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 23:11
  3. Anyone in NW got a spare full size 17" Wheel going spare?
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2006, 01:51
  4. got 40k to spare?
    By Harry in forum General Chat
    Last Post: 24th November 2006, 12:10
