Thread: white gunge
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    Default white gunge
    went to top up my oil took the filler cap of and was greeted with white gundge around the rim and on the cap, checked the rad bottle for oil nothing checked under and around engine nothing no leeks all seems fine.
    any ideas as to the white gundge got there.
    thx guys
    Feb 2006
    Guttedsville
    Could just be a bit of moisture getting into the top of the cap.
    Deffo get it checked out though, if just for piece of mind.
    Regular Member ion's Avatar
    walsall
    Get it checked to be safe, but if you do alot of local journeys it might just be moisture sitting there as Andrew said.
    The engine doesn't get hot enough to burn it off if you do short journeys.
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    Presume the oil looks okay when you dip it, not like a Cadbury's brown?
    Keep your eye on the colour of the expansion tank. This could be an early warning that your head gasket is weak. Any white smoke on start-up?
    Mileage : 000
    It sounds like the standard 3.2v6 gunge. do you do short journeys, It is the cold air condensating the oil on the filler tube, mine does it as I do short journeys, but when I go on the motorway it clears it out, you will find that it goes no further than the oil filler tube.
    Regular Member Turbo Signum's Avatar
    Glasgow
    emulsification (water in the oil), Very common on cars that don't do a large mileage or sit around for lond periods of time. As every1 said aslong as oil level is good and coolant level is good it won't b anything to worry about.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    ive got the same probs with my 3.2, seems pretty normal to me lol, my expansion tank is clear and the oil is fine, its been like it since ive had the car in october so i guess if anything was going to go wrong it would have by now
    Glasgow
    generally not a serious problem if its only a little on the cap and around filler u just wipe it with a cloth and get stuff out with fingers or screwdriver tip, if it is quite bad due to lack of oil changes or only covering a small mileage u can get engine flushes to clean it out!
    Here, there and every where!
    See HERE m8
    Apr 2006
    Vehicle : saab 95
    Engine : 2.3t
    thx guys i wasnt too worried as i couldn't find any leaks my bro said he'll do a compression test to see if there is any leaks, i do about 40 miles aday 25 of those on the motoway but i do a lot of lil trips too.
    ill give it a wipe and see if it appears again.
  1. GUNGE COMING FROM THE EXHAUST. "Emissions?".
    By felixx in forum Diesel Engine related
    Last Post: 16th February 2011, 06:42
  2. I'm all white now...
    By jimbojetset in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 16:56
  3. Green gunge around tail lights
    By signumboy in forum Styling
    Last Post: 28th July 2009, 16:42
  4. White White Wheels!
    By sduk in forum Non Vectra C/Signum Album
    Last Post: 16th January 2009, 20:02
  5. white one
    By garvey in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 4th May 2008, 19:54
