Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: quick hid question/problem
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default quick hid question/problem
    had hid kits for the last few years, hoping someone can help.
    a week ago my left light flickered off, i turned off car, wiggled around the wires which isnt easy on a vec c, started car, fine for a few days. now its doing it again, bulb check light and no headlight, if i start the car i dont get the warning until i turn on the lights, when the lights are first started i get major interference on my stereo, like an old atari. it stops after say 10 seconds. im thinking ballast rather than bulb, what are peoples thoughts. also how much difference would there be between a 55w hid ballast and a 35w, light output wise. i have some spare and in this rain, only really want to change the effected one until i can get a new set.
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    get someone to use unspoken software to tell the car its running xenons not halogen and you wont get a bulb check i done mine and havent had a problem since i fitted them
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    i have cancellors, its not lighting the bulb at all now, thats the problem. and with the interference on the stereo when first fired up im thinking ballast
    Dec 2011
    liverpool
    6 Post(s)
    how long they been in for and are they mounted oroperley ?
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    been in for 3 months, the ballasts are 1 year old though, and mounted under the headlights
    Dec 2011
    liverpool
    6 Post(s)
    surely it shouldnt go after a uear and ye in the correct place i would advise anyone to mount them properley but if the bulb aint lighting it could be the ballast is it just one or both
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    just the one, its odd tht it went off, then i turned car off, restarted, worked for a few days, now wont light at all and i get this squeel from the stereo when i first turn on the lights. il change the ballast and see what happens. have to have 1 35w and 1 55w for a while until i can get a new set, if changing it works of course.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I seem to recall i had a similar problem,more of a niggle really. I put it down to the connectors being dodgy,if i wiggled them they worked. Solution?....I cut the original connectors off and used crimp on connetors..Job done
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    ive wiggled like mad and no joy
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    are we still talking bout your car???
  1. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  2. Quick question.
    By RN37 VXL in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2010, 11:50
  3. quick question
    By aledjones_lex in forum Suspension, Wheels & Brakes
    Last Post: 25th April 2010, 18:30
  4. Got a quick question...
    By n_hudson in forum Handling & Braking
    Last Post: 9th April 2010, 13:51
  5. GID Question?? Quick!! lol
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2009, 15:59
