Results 1 to 10 of 14
Thread: Auto Dim Mirror
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Default Auto Dim Mirror
    right i have got a bracket which i am assuming is for a sensor of some kind so what else do i need obv a mirror and the cowling around i have a 2006 SRI will i have the wiring or were will i find it so i can have a look cheers lads
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The bracket will be for the rain sensor bud, if you want to go the whole hog, you'll need the rain sensor, either a new windscreen or some black film cut to the correct shape and chances are you won't have the loom fitted
    Then you'd need the mirror programmed in for full function
    Dec 2011
    liverpool
    6 Post(s)
    so i need a rain sensor roof loom from another car some tinting film rear view mirror and the surround for it ? and some tech 2 and ill be motoring
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Basically mate, it'll work without tech 2 (or other) but programming it in will stop the mirror dimming when the car is in reverse and when the drivers door is open.....depends how fussy you are.
    When buying a rain sensor you could also fit the auto light switch and with some tech 2 it'll also work
    Dec 2011
    liverpool
    6 Post(s)
    is it all worth doing at once and how much am i looking for this i wanted to pick bits up as i go at low prices in no rush so wondered what bits i need like a parts list instead of paying out in one hit
    Regular Member farley2708's Avatar
    antrim n.ireland
    dont think you'll need the 'tech 2' should just be a case of fit the mirror onto your windscreen attach the loom/ribbon cable,feed this from the front of the car under the roof cloth to the left side of the boot and plug it in,on the bottom of the auto-dim mirror there is a LED light mood lighting of the gear stick area) this will be more visable at night,lets you know it has power aswell,as for the surrond hen i fitted mine i fitted the surround of a zafira,its a bit smaller in size
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by antowens View Post
    I got EVERYTHING from a certain ebay seller for 60 quid.....that was the roof loom, rear interior light, illuminated sun visors, map lights, auto dim mirror and rain sensor.
    Tbh it's worth dropping the headlining and just doing the lot I went one step further and fitted a new windscreen but that was just me being extreme
    Dec 2011
    liverpool
    6 Post(s)
    got to be a bargain hasnt it need to find meself something like this so do all preface roof looms have all the wiring for the interior light and sun visors and will mine just unplug and the other one plug in
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Most of the pre-face cars have the loom but....you'll need a facelift loom with the wiring for the light sensor
    Dec 2011
    liverpool
    6 Post(s)
    so a preface loom is useless to me i need the facelift loom and the preface bits should fit it
  1. auto dim mirror
    By Ray_Ray280 in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2011, 00:31
  2. For Sale: auto dim mirror
    By daddyjay in forum Parts for sale
    Last Post: 5th June 2011, 18:00
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  5. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
