Results 1 to 5 of 5
Thread: problems
    Dec 2005
    RUNCORN
    Thumbs up problems
    hello all got a slight problem with my vectra it has a light on the dash in yellow with a stearing wheel and ! in it been told its a problem with the power stearing assist all it does is make the car stearing a little heavey when driveing slow told theres no problem with ti but wont pass a MOT with it on
    can anyone tell me were about this bit of kit is on the car and if and were i could get a newish one and does it need to be put on the computer to accept it
    if im right about this or wrong can someone tell me plzz as any help would be greatfully recived
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Have you checkeds the power steering fluid level?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    First check fluid level
    Aug 2012
    Well you're right it won't pass a "proper" MOT but don't think I have ever see a garage check to deeply:
    MOT Test of Steering
    Steering: Inside the car MOT checks
    Steering wheel and steering column:
    • Steering wheel is in acceptable condition
    • Steering wheel is securely attached to the steering shaft
    • A steering lock mechanism must not be missing, inadvertently engaging or inoperative
    • An electronic steering lock malfunction lock warning must not be indicating a malfunction
    • An electronic power steering malfunction indicator lamp must not be indicating a malfunction
    • Upper bearings of the steering column are inspected for wear
    • Steering shaft is checked for excessive end float
    • The clamping bolts are all checked for security
    • Split pins and locking nuts are also checked.
    • 'Free play' in the steering is checked*
    • All flexible couplings and universal joints are checked
      Pretty sure the new unit would have to be programed
    Dec 2005
    RUNCORN
    yes have checked the fluid its fine as i said i was told that it is a server for the power stearing but does anyone have said thing and or tell me were about it is on the car please
    thanks for the help upto now
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
signum Adaptive forward lighting fault
