Thread: How do turn off auto air-con?
    Birmingham
    Default How do turn off auto air-con?
    Hi guys,
    On the Insignia. the air-con comes on automatically when you start the car, how on earth do you set it so that its not auto on??
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Most newer cars at work have the on/off setting in one of the menus for the dash screen/display, found anything in there?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    its in the manual fella
    Full Member
    South West
    Don't go getting Aircon and Climate control mixed up. Two different things really.(when referring to the manual!) ECC is the overall name for the heating/air conditioning. When refereed to as aircon is just the the cold element of the ecc.
    It can be turned on/off using the * button which should be above the re-circulation button on the left of the display panel.
    To ensure its on/off Hit the info button on the console - scroll through and it will bring up the climate control current settings. As you press the * you will see it turning on/off
    This had me totally confused when making sure my car was set up for the stop/start to work.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    I had a hired car for a few weeks, it was something that annoyed the crap out of me too... I worked out in the end how to turn off the Auto ECC, but the fans still kicked in on almost full everytime I started the damm car regardless of what temp it had been set to before switching off.
    Full Member
    South West
    The fan speed on startup can be changed in the config as well.
    Birmingham
    ok, im.familiar with * meaning aircon , but surely when the light is on this means aircon is on. im confused a little, dont mind the CC being on but dont want the AC on unneccisarily.
    Bye bye Vec B
    - Hello Siggy!
    Full Member
    South West
    hang on mate, ill go out to the car and check the settings....
    Full Member
    South West
    Right, Goto Config, Veh Settings and Climate and Air settings. You can then select "Climate Control" This will determine if the * is illuminated or not when you start the car. Its confusing the way its worded - but i guess thats VX for ya! Hope this helps mate.
    Page 115 in the manual - which is not much help until you figure it out by playing first!
    Birmingham
    Cheers pal, sussed it yesterday. Basically I turned off the aut0 climate control, is that what you mean?
    Bye bye Vec B
    - Hello Siggy!
  1. Turn off auto radio?
    By Rab in forum Vectra C / Signum Troubleshooting
    Last Post: 26th January 2014, 19:27
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. How do you turn off the auto light switcher
    By freqfreq in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2008, 22:48
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
vauxhall insignia air conditioning
vauxal zafira ac always on
how to turn off air con in vauxhall astra
vauxhall code 4 air conditioning off
insignia climate control
astra stop aircon auto on
insignia sri how to turn on air con
astra h elite climate control on and off
how to switch climate conteole off on astra j
the air con on my astra will not turn off
insignia radio auto off
climate control on vauxhall insignia
how to turn on opel insignia ventilator
zafira air con light wont go off
air-conditioning light keeps coming on vauxhall zafira
zafira air con light coming on
zafira b air con light comes on with fan
how opel vectra b a.c us turned on
disable insignia aircon startup
vauxhall insignia air conditioning comes on when starting
opel astra h ac switfh always on
opel astra h ac heater control problems
opel astra h ac switch always on
vauxhall insignia climate control problems
