Thread: Strange Ball Joint Issue
    East Ayrshire
    Trim : SRI XP1
    Default Strange Ball Joint Issue
    Following on from my other thread here http://www.vectra-c.com/forum/showth...or-Alloa-area)
    Summed up, steering judder at 60mph +, pulls left when accelerating and right when slowing.
    Had the car in the air today and the boot on the front o/s control arm ball joint is loose, eg the top clip appears to be gone. I can't find any play in it tho, however I also can't find play in anything else and nothing else appears faulty. There is also a knock when going over bumps, all the other usual suspects have been checked and are in good order. When the wheels are running whilst lifted off the ground, the judder is also kicking in at the same speed. Given that, my mate thinks it may be a driveshaft causing it. Has anyone else came across this where the ball joint is failing but no obvious play?
    I need to replace the arm anyway as I have my MOT on monday coming but any advice would be helpful
    East Ayrshire
    Trim : SRI XP1
    Bump, anyone?
    East Ayrshire
    Trim : SRI XP1
    Sorted, new wishbone and all is well. May be something for people to keep in mind. Mine had no play whatsoever, but clearly the forces at 60mph+ are more than I could replicate
    Nov 2012
    Birmingham
    How much did it all cost you?
    East Ayrshire
    Trim : SRI XP1
    £69 for the wishbone and 40mins of my time
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Cheers stevie for posting your outcome mate, gives me something to look into. Everything perfect now?
    East Ayrshire
    Trim : SRI XP1
    Yup, Took it out not long ago and the wheel is once again sitting straight, no judder and no pulling. I can now relax a little bit, well until the MOT on monday!
  1. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  2. failed MOT ARB Ball Joint
    By howieallstars in forum Handling & Braking
    Last Post: 15th November 2010, 16:50
  3. Gearknob ball joint
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 21:57
  4. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
  5. Ball Joint failure
    By peter142 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2008, 18:18
