Thread: what can cause a brake pad check light to appear randomly?
    newport
    Default what can cause a brake pad check light to appear randomly?
    was told there was only one sensor (on passenger front wheel), its been cable tied to hold it in place, i thought that must be the cause of it, so cut off the sensor end and joined the 2 wires together temporary, but it still comes on every now and again, and stays on till you restart the car?
    fluid is about centre between the max and min marks in the resevoir, could it be that? if so how do i find out which brake fluid it takes?
    its a 2003 1.8 sri
    The brake pad warning and brake fluid level warnings are not the same
    This suggests the cable itself is at fault and needs to be replaced
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Possibly poor connection if its only intermittent
    newport
    how far up does it go before it connects to the main loom?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Changed my sensor lead a few days ago, cost £12.26 with trade card from vx. The lead is about 30cm long.
    It goes from the NSF brake pads to around the front strut and plugs into another plug inside the wheel arch.
    Take the wheel off and turn the steering wheel fully left, better access.
    newport
    cheers, will have to have a better look, its no better with the wires joined about 3" from where the sensor was, so the problem must be further back
    Chelmsford
    When I did my pads a few months ago they'd worn down enough that the lipped edge of the disc had made contact with the sensor and mangled it...
  1. Check Right Brake Light
    By Dobs in forum Engine & Drivetrain
    Last Post: 20th October 2012, 09:13
  2. Check Brake Light
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 11:15
  3. Brake Light Check
    By tangoman in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 22:11
  4. Check 3rd Centre Brake Light
    By Downunder in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2007, 16:14
  5. Check rear brake light.
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2007, 20:04
