Thread: Rear interior lights.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Default Rear interior lights.
    Ok, here goes. I hope i'm not repeating anyone elses question.
    A few years ago (1995-1998) i had an Astra estate which had the rear interior lights incorporated in the rear grab handles just above the rear doors. From memory the handles look very similar to the Vectra rear grab handles.
    This is similar to the Astra grab handle i mention above.
    I'm curious to know if anyone knows if this is at all possible as an alternative to the one most people seem to have done which requires cutting the head lining?
    Many thanks,
    Mark.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    I dont know if they are the same size as the vectra, looks good maybe worth a try...
    Is there space above the front seat belt on the pillar trim...
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Not sure about the size, but being from another Vauxhall, alot of parts are shared between models across many years. Can't see then designing different sized grab handles, after all, the latest Corsa uses the same exterior door handles as the Vectra.
    My main concern would be the curtain airbag regarding the space behind the headlining where the existing grab handle is. Obviously the headlining would still need modifying to allow the light to fit.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Having looked at the parts listing on ECAT24, seems like it's not going to work. Might have to have a look in the car later to see if it's possible or not. Would have been a neat mod if it was possible, not keen on the standard rear light mod, but even less keen on the black hole that is the back seat when it's dark & you open the doors.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    It might interfere with the curtain air bags too.
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    i was thinking about doing this with vec b illuminated handles for my preface c
  1. rear interior lights
    By andy_richmond in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 23:10
  2. Rear Interior Lights in Estate
    By chaddopete in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 23:10
  3. Rear interior lights
    By Toyotacelicagt4 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 19:34
  4. Rear Interior Lights
    By Micknal in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 21:03
  5. Rear Interior Lights, is it possible?
    By Drewm in forum Bodywork & Interior
    Last Post: 19th January 2009, 12:18
