Thread: Watched wheelers dealers...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Watched wheelers dealers...
    Been watching wheelers dealers and on this part replacing cooling radiator, he was ensuring radiator air was removed... I started to realise, car radiators is alike home radiator...
    Wheres the air bleed valve for vectras?? Lol
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It's called the expansion tank the high point in the system and is an auto bleed device
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    On your house radiator the flow and return pipes are at the bottom so air can sit at the top(the highest point), on the Vec it cant and always returns to the header. If you go to a large commercial building you may well find that the flow and return pipes on radiators are at the top, this saves someone having to bleed 300 radiators.
    11 Post(s)
    Quote Originally Posted by Humourbash View Post
    No, they used to be before the addition of the header tank where any air now ends up. See Paulhb's reply.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by Das View Post
    our house ones are at the top, still have to blead the damn things though
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Weird cos i'm a plumber, water inlet at bottom and outlet at bottom still need to bleed rads, same for cooler rad on car both bottom. Surely it should be a bleed valve as air stays at top making it work less effect?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    On mine the flow pipe is at the top and the return is at the bottom. I can see where you are coming from right enough.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    However how many radiators have a connection from the top corner of them to the expansion tank just like the vectra allowing air trapped at the top to escape to a higher point in the system namely the expansion tank
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Of course!!! Remember now theres one pipe there. Cheers paul. :-D
    From memory, a car heater system is high pressurised, whereas a home system is not (pump driven only)
  1. Havent watched this in a while
    By shaun260589 in forum The 'Off Topic' room
    Last Post: 19th January 2010, 14:00
  2. things we watched as kids
    By SRimonkey in forum Comedy & Humour
    Last Post: 20th July 2009, 20:08
  3. Watched W
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 9th February 2009, 00:28
  4. Just watched Top Gear...
    By Duncan in forum General Chat
    Last Post: 4th November 2008, 10:12
  5. Watched Deathproof
    Last Post: 25th February 2008, 20:47
