Results 1 to 10 of 21
Thread: Power steering fluid reservoir location
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default Power steering fluid reservoir location
    Anyone know where it is? It's chucking it down and i fear the fluid is low.
    Underneath the offside headlamp, so it's a front bumper off job
    Very rare for the level to drop below the minimum
    I am now on my fourth Power Steering Pump within the last 18 months
    What makes you think the level is low?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    It's been suggested to me that the fluid might be low (first thing to check) although i have no warning symbol. Basically my steering is groaning when steering left to right. I don't want the fluid to run dry so i thought it would be worth the check. Bit of a swine to get to though it seems. I'm wondering if the groaning/ creaking has anything to do with the strut tops that have just been tightened up?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I thought it was under fuel filter?! Screw with star hole.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by Humourbash View Post
    Not on the preface
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Think mine might need a top up too? Steering on my 2.2 is a lot heavier then the CDTI...
    Isnt it under the drivers headlight? Bumper off jobbie...
    Quote Originally Posted by BigWilko View Post
    The Power Steering Pump is naturally noisey
    However, in colder weather it is even noisier
    It won't run dry, the reservior is enormous
    The earlier version also has a level warning indicator, so that will appear first
    Remember, the handbook advises NOT to turn the steering wheel when the car is not moving, this damages the electric motor in the Power Steering Pump
    The original Power Steering Pump failed this time last year
    When switching off one night the warning light briefly appeared
    The following night it did the same, but for longer
    The next day the pump failed to switch on
    The replacement pump lasted just two days, and it's been a saga ever since...
    I personally think the rack itself had failed
    Feb 2011
    Selby
    On some models it's behind the engine, on top of the steering rack. It is on my preface 2004 1.8 for example. It's not designed to need topping up, hence the awkward location. It's only meant to need it every 80,000 miles or so. And you must use the proper green GM fluid. Anything else will damage the seals.
    Quote Originally Posted by rich r View Post
    This is the Y30DT / Z30DT sub-forum
    Service Plan G clearly shows that the level does not need to be checked on the Vectra C, all engines
    However, Point 13 shows that the operation must be checked at each service, and the system checked for leaks
  1. Power Steering fluid reservoir
    By humphshumphs in forum Engine & Drivetrain
    Last Post: 16th September 2010, 19:09
  2. Power Steering Fluid
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 16:16
  3. Power steering fluid reservoir
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2008, 19:44
  4. Where is my GSi's power steering reservoir?
    By GSiFan in forum Suspension, Wheels & Brakes
    Last Post: 21st December 2007, 15:44
  5. Power steering fluid reservoir
    By skinnyseand in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2007, 19:28
how to top up power steering fluid vectra
vectra c power steering reservoir
vectra c 03 power steering fluid location
how do I check steering fluid on vectra c
power steering reservoir vectra 54
location of power steering bottle and photos on vectra c
vectra c power steering fluid
power steering reservoir on vectra 3.0 diesel
vectra sri fluids
power steering reservoir for vauxhall insignia 2004
vectra c 1.8 power steering fluid
https:www.vectra-c.comforumshowthread.php177808-Power-steering-fluid-reservoir-location
vauxhall vectra power steering fluid top-up
where is the power steering pump located on a vauxhall vectra 1.8 club
vectra 3.0 cdti power steering
vectra 3.0 cdti power steering reservoir
vauxhall vectra c 2.2 powersteering fluid reservoir
vauxhall vectra power steering reservoir location 3.0 cdti
vauxhall vectra 1.8 power steering fluid top-up
location for power steering fluid vocal in vectra
where is power steering reservoir on vectra sri 07
power steering fluid vectra c
